tree shear?
/ tree shear? #11
14" Timberwolf tree shears for skid steer loaders - TreeShears.com - DYMAX
I have used what they call the timberwolf 14" from Dymax since 2002 my ASV 4810. if you have a skid-steer with an electrical quick connect circuit the accumulator arm is a slick unit...as others have mentioned it is a wicked rugged unit. might want to reinforce around your loader arm pins as its pretty easy to put a lot of force on them when you have hold of a 12" white pine thats 50 ft tall...
I did 10+ acres of abandoned X-mas trees last august with the shear- some of the trees were 10+ inches DBH- laid them down in big bunches, used a brush grapple to pick them up and haul them to a chipper- we filled 5 45ft chip trailers with the biomass from the x-mass trees- thats about 60 cords worth of x-mas trees...
/ tree shear? #12
I like the looks of the the Timberline HT, especially when it comes to cutting firewood. The Dymax doesn't rotate.
jmf
/ tree shear? #13
jmfox
That long, unsupported cutting edge of the Timberline would scare me. I don't think it could take the abuse. The potential to flex and bend over long term will be a problem The rotating aspect could be useful. However, if it rotates, it needs to pivot around a single axis. This creates a weak point in the design.
I do occassionally cut a downed tree to make it more manageable. I just drive up to the trunk, tip the shears down vertically and make the cut. Not a big deal.
A single cutting shear can also create problems on big trees. On big trees, the shear can become wedged in the tree if it can't make the cut. The blade is not as wide as the cut and can get stuck. Even on my double cutting shear, it can get wedged at times and I still have the blade edge outside of the tree. I can get it out by opening a closing the blades a few times. If the blade is completely covered by the tree, it may require a chainsaw to relieve the pressure and try to free it.
/ tree shear? #14
Feller-bunchers have tongs or a hydraulic clamp that's several feet above the knife. Never used one; but I'd have to guess it helps stabilize the tree to keep it from tipping over into the cab - as well as a means to stack the tree and move it, etc.
These SS tree shears - how tricky is it to keep the tree from tipping over into your lap??
Do you angle your cut just slightly at a forward tilt and use the shear to push the tree over when the blade has cut through?
Curious... thanks.
AKfish
/ tree shear? #15
The acumlator on the Dymax is well worth the extra money. I use mine to shear and stack for the knuckle boom feed chipper.It is a well made unit.
/ tree shear? #16
How much is the extra money for a Dymax?
jmf
/ tree shear? #17
Curious... thanks.
AKfish
The tree tends to almost always fall off to the side. I tend to cut slightly at a forward tilt and then it tends to fall forward and to the side. On cedars and bushy trees, my brush guard also tends to push the tree forward and to the side. My brush guard does a great job of dropping them forward and protects the machine from scratches/damage. They tend to fall backwards when cutting up hill or up slope. On those, I tend to tip it slightly forward as it cuts.
/ tree shear? #18
jmf
My Dymax Ranch Axe with brush guard was about $6000 3 years ago. I added my own spray kit and use a product called Pathway. Have also used Tordon mixed with diesel. I copied the Dymax version for my sprayer. The Dymax sprayer at that time was another $1000 which is overpriced. I have a push button switch attached to the control stick in my cab. Just reach over and push the button with thumb, without movinvg hands from the controls. The spray kit keeps the hardwoods and brush from growing back after the cut. Cedars won't grow back unless a branch is left on the stump.
/ tree shear? #19
The dymax timberwolf w/ accumulator is somewhere around 10K.
/ tree shear? #20
I have a friend that is selling a 14" Dymax shear here in Connecticut. He bought it a couple of years ago to clear a fairly big building lot but he really hasn't used it since. If anyone is interested I could get some more info.
Kubota LX2620 (A53317)
2018 Ford Explorer AWD SUV (A59231)
2018 Ford Explorer...
Towable Trash Pump (A59228)
Towable Trash Pump...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
2021 Takeuchi TL10V2-2 Track Loader with 76in Tooth Bucket (A61307)
2021 Takeuchi...
2023 JOHN DEERE XUV 590M S4 UTV (A59823)
2023 JOHN DEERE...
