Tree remover
/ Tree remover #21
Think about that... you put a long lever on the end of the pt and start prying on it. Heck, I've bent my forks several times by prying on stuff and they are only 3' and a lot thicker steel than the mini hoe.
/ Tree remover
David is right. Consider this, a 10 to 1 ratio on the 425 with a lifting force of 800 lbs, and a good lifting arm. You now have 8000 lbs of lifting force. However, if the object is 9000 lbs, the PT rear end will lift.
/ Tree remover #23
BobRip said:
With the foot on the tree remover, you have leverage and the 800 pounds of lift from the pt will be multipled by a factor or 3 or more. No loads will be put on the minihoe that are greater than normal because you are limited by the PT weight or the relief valves.
A multi-thousand pound load on the tree trunk does not mean that your pt will be lifted from the ground or tipped over. Its a lever after all.
http://math.nyu.edu/~crorres/Archimedes/Lever/LeverIntro.html
And its not the load on the mini-hoe that is the problem. The arm of the hoe is a box beam, with relatively thin sides as I recall from other threads. (1/8 inch steel?)
You have a beam with a large load on it in the center of that beam. The load can be large, since you have leverage working against you here. This beam was not designed to take a serious load at that point. Buckling will indeed be a real threat. My guess is a crumpled mini-hoe arm soon.
John
/ Tree remover #24
Archimedes' Lever
John
Almost all of the force will go to the foot on the tree puller, not the PT.
/ Tree remover
Archimedes' Lever
John
When a PT exceeds it's lifting capabilities, the back end starts to rise. This is the same as the tree and the lever lifting principle. If the machine can not lift the tree, and you keep adding hydraulic fluid to the lifting cylinders, guess what. You have just made the PT a lever by rotating the PT on it's front wheels, and the rear end will come up. Have you ever seen that tool that they use to move a train car, years ago, and they might still use it. It looks like a long pole with a wedge on the end, and one man can move that car by the lever principle.
What's that old saying, If you give me a lever big enough, I will move the Earth.
/ Tree remover #26
JJ I agree that if you need to lift 9000 lbs the PT rear end will lift, but I would be pretty happy being able to pull out a tree that requires 8000 lbs of lift. Right now i can only pull a tree that needs 800 lbs of lift. To me that sounds pretty good or am I missing something.
/ Tree remover #27
This has all been interesting but did anyone look at the specs? The tree jack alone weighs over 1200lbs. with most of the weight several feet out from the attachment plate. You would have to use some kind of space age materials to build one long enough to have any real leverage and also light enough to lift with a pt425.
/ Tree remover
Scott. As you know, the 425 can lift around 800 lbs. If you use this leverage in a lever situation, you should be able to lift quite a bit more. You probably already know about lifting with a boom pole. The further out you try and lift, the less you can lift, but if you add some weight to the rear end, you can lift more.
A simple lever would be something like a seesaw. Equal weights on each end of 100 lbs, and you have balance. Now, move the fulcrum toward one end with a 10 to 1 ratio, you should be able to lift 1000 lbs on the other end.
Someone mentioned the weight of the tree puller in the skid steer add. The weight of the tree puller has to be including in the weight of the pulling force.
Actually, it could be lighter and stronger and still do the same job.
/ Tree remover #29
Definitely. I bet if you built it out of a 4x4 1/4" box beam, it would have more then enough strength for the job.
Alternatively, you could make it attach to the end of the minihoe with a swivel, so you get extra lift height at the PT end of the prybar. This will not damage the mini hoe (I have picked up the back end of the PT with the minihoe when prying on rocks with it, and didn't change the shape of it). This might make it more complex, since either you will have an extra arm flopping around or need another hydraulic cylinder.
/ Tree remover #30
What you are missing is the same thing that several other responders are missing.
IF you can apply 8000 pounds of lift to a tree, then there is also an 8000 pound load applied to that point on your minihoe arm, acting in the opposite direction. Since the arm is apparently a thin walled box beam, it is likely not engineered for loads of that magnitude at that point, and in that direction. It may well crumple, like an empty aluminum soda can. Once the arm has buckled, it is likely that the mini-hoe will be less usable than it was before you tried to pull that tree. It will be far more flexible of course once it has buckled, so you could even use it to reach around corners. Just think of the new uses you will find for your PT then?
John
/ Tree remover #31
Sigh. It is not the PT that I'm expecting to tip over. Assuming that the PT mini-hoe arm is truly a thin walled box beam, it is not designed for significant transverse loads along the beam. Say, as some have suggested, that you will be able to apply a load of 8000 pounds of lift to a tree. Then you must also apply an 8000 pound load at that point on the beam, even though the pt itself will not tip over, since it only feels an 800 pound load. If the arm is not capable of supporting this load, then it will likely fail. The failure, when it occurs, will be rather unpredictable - buckling is often so.
It is your equiptment of course.
John
/ Tree remover #32
Are you guys really talking about try to pull a tree out of the ground with a PT-425? A tree that weighs more than the tractor? :eek:
Will a mod please move this to the Safety Forum, so that we can all enjoy the fireworks. :p
/ Tree remover
John
I am not saying the mini-how can handle the load of lifting a tree in the situation we are discussing, however, some of the mini-hoes use thicker tubing. I am saying that if you use an [appropriate ] lever and the right ratio, you can do much more work than the 800 lbs of the 425. You haven't said whether you agreed with the lever principle.
What ever one does, you must have the proper tools, the know how, and the ability to do it safely.
/ Tree remover
Exactly Are you such an unbeliever that you don't understand the principle of levers. Have you read all my post?
/ Tree remover #35
I understand them very well, JJ, and yes, I have read them.
/ Tree remover #36
I'm pretty sure you could pry up an 8000 pound load with a PT425 IF, and only IF, the lever you are using is sufficiently strong enough to support 8000 pound loads. With proper leverage anyone can move anything. As mentioned earlier, I have used pry bars to move rail cars by myself. I had a job in the mid 80's driving and loading millitary vehicles from A.M. General's plant in South Bend, In to rail spurs around the area. We had to install the plates between the rail cars to drive from car to car and sometimes the cars were too far apart for the plates, so we had this big pry bar thing and one person could move a huge, double height rail car by themselves.
The real questions are:
1. How long of a lever would you need to move/pry that 8000 pound load out of the ground with only a 5' (or less) lift? You may only get a few inches of movement 10' out from the PT lift arms.
2. How strong would that lever have to be?
3. How heavy will that lever be?
4. etc....
/ Tree remover #37
4. etc....
5. Yikes, I got it! Now what? :eek:
...which was my point.
/ Tree remover
I do not understand your point at all, so what is your point. Can it be done, and not to use thin wall tubing doing it?
/ Tree remover #40
I agree with all that you say here.
John
E-Z TRAIL 1020 GRAIN CART (A64278)
E-Z TRAIL 1020...
2022 EZ-GO ELITE...
UNUSED PARBREAK GB232-79" HYD GRAPPLE BUCKET (A65055)
UNUSED PARBREAK...
2007 JOHN DEERE 450J LGP CRAWLER DOZER (A63276)
2007 JOHN DEERE...
UNVERFERTH 14' FIELD CULTIVATOR (A64278)
UNVERFERTH 14'...
UNUSED PARBREAK BC352-72" HYD BRUSH CUTTER (A65055)
UNUSED PARBREAK...
