Tree remover
/ Tree remover #61
RegL said:
Why not tie off 20' up the tree and use it's trunk as the lever as long as it is strong enough.
You know I have done that, but never compared that to the tree remover that we have been discussing. Even with a 20 foot lever (the tree), I cannot pull the tree over without cutting many roots. I used a high lift jack to pull the tree and a comealong. I probably had several thousand pounds on the tree.
With the tree puller, I can apply lift to the tree. I was told by a lumber jack friend that trees are a lot easier to pull up versus sideways. If you think about it, in nature there is very little lifting force on a tree, but most trees see a lot of side forces from wind and are adapted to it. Life is very efficient and does not waste effort on things it does not need.
/ Tree remover #62
Bob, I know what your saying about trees adapting to their environment, but it's been my experience that on small trees that I can't lift out with the loader, I can easily raise the bucket a ways and push them over.
How about a stouter version of one of these. You would get both lift and pull.
Ideal Alternative to a Tree Spade
/ Tree remover #63
Very interesting. I have to think about this.
2021 Deere 331G (A53317)
2021 Deere 331G...
2018 FORD TRANSIT 350 4X2 CARGO VAN (A59906)
2018 FORD TRANSIT...
2015 FORD F-250 SUPER DUTY (A60736)
2015 FORD F-250...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
2018 Claas Volto 900 (A53317)
2018 Claas Volto...
PT 1000 Gallon Supply Tank (A57149)
PT 1000 Gallon...
