tree planting auger
   / tree planting auger #21
If you're planting bare root trees you might be able to put a spade in the ground, open the gap a bit and set the tree in. Or build a tool to hook on the outside edge of a loader similar to the method to bolt on a tooth bar. Then press your loader down move forward and backward a couple of inches and move on.
That German rig is a beauty.
It certainly is. I need to beat the bushes to see what US distributor imports Fehrenbach equipment. Per MacGregor's comments, I agree that purchase of a complete unit is better than building one from scratch.
   / tree planting auger #23
How large are your seedlings?
I just planted a bunch of bare root sand pines and used a $17 24" bulb planting auger on a cordless drill. Quick and easy!
I bought a dibble bar but it wouldn't go into my soil so it sits brand new in the wrapping.
   / tree planting auger #24
Three point post hole digger with a retrofitted Gravely rotary plow auger:
   / tree planting auger #26
I missed the part of your description saying that you didn't want to use your 3pt.
You could buy or build a hydraulic auger and fabricate a bracket to mount to the side of your loader, then use the loader to raise and lower it.
I use my Gravely walk behind with a sulky with the rotary plow pointed straight down to plant my saplings, it works perfect.
IRTPL 10,000 LBS TWO POST LIFT (A58214)
IRTPL 10,000 LBS...
CFG Industrail MX15RX (A53317)
CFG Industrail...
2020 Freightliner M2 106 AWD Altec DC47TR Digger Derrick Truck (A60460)
2020 Freightliner...
2005 MACK CV713 TRI AXLE 16FT DUMP TRUCK (A59575)
2005 MACK CV713...
2003 Big Tex 10PI...
2006 Tusk 500 PG-16 Forklift  3-Stage 188in Lift with Aux Hydraulics (A56436)
2006 Tusk 500...
