Posthole Digger m59 with posthole digger on backhoe (and rock rake up front)
   / m59 with posthole digger on backhoe (and rock rake up front) #11
Charles,
Thanks buddy!
Charles,
By QCS do you mean the quick connects? I'm about to rig up a log splitter to my hoe and I was wondering if I had enough flow to run it off the thumb lines. It's gonna be a 4 or a 4.5 inch cylinder, and it calls for 11gpm. Cutting it close I suppose.
How much are the QA bucket ears?
-Mark
Yeah, I think the pioneer quick connects have a max flow of 12. Why run it off the thumb - do you have any other remotes? I find the front remotes REALLY useful if you don't have them, as you can run a lot of bobcat stuff - basically makes it into a big skidsteer. I'd tend to put the splitter on a FEL QA blank for ease of movement too.
Why? :confused: I dig full depth all the time with my 2 footer.
Yeah, I could dig that - big oak roots and boulders though I doubt. Its really convenient to have the auger on the hoe, but you lose a lot of horsepower by doing so - I forget the math, but I bet I'm running the auger off 1/3 the hp you are effectively (W.A.G)
   / m59 with posthole digger on backhoe (and rock rake up front) #15
Charles,
No, I don't have rear remotes. :mad:
I thinks its about 2k to add them or so. So I was figuring I could put quick disconnects to the thumb rod and use that instead. Are the factory also limited to 12GPM (i.e. are they pioneers)?
   / m59 with posthole digger on backhoe (and rock rake up front) #16
Charles,
Once you make a few holes you will really like that setup, I have a similar unit on my 110tlb and it works well.
   / m59 with posthole digger on backhoe (and rock rake up front) #17
This past weekend I just picked up a Mcmillen X1475 for my 110 tlb. Right now it is setup with a SSQA to go on the front loader, and the couple of "new toy" holes I dug with it went great, much better than a 3 pt hitch type I used before and I won't even mention how much better than digging by hand!!!
Have you guys ever used a hyd phd on the loader also? I am just wondering how it compares to on the backhoe? I need to line up some fun projects for winter, so is it worth making the swap? I would be making the mount myself.
   / m59 with posthole digger on backhoe (and rock rake up front) #18
Dude- I'm soooo jealous! I would love to have that setup. I'm about to dig about 150 or so holes for a horse fence and man that setup would be sweet!!! Very nice looking rig!
   / m59 with posthole digger on backhoe (and rock rake up front) #19
popped for RFB.
I've been using the 2 foot auger to punch tree and hydrange holes. Its a planting machine (pun intended) wife and I got 6 3 gallon hydranges planted in untouched forest soil in around 15 minutes - longest thing was moving the machine.
Be tough to go over a foot or 2 down with the 2 footer - think the 9" would do a lot better but haven't tried it yet
You can actually dig a foot or two with that thing? What, no rocks where you live? I'm fairly sure that I could never use an auger for anything.
Your machine does look pretty nasty. I am kind've surprised that you can run that rake up front though - I would've thought that 15gpm isn't enough.
JayC
Yeah, came rigged for the FEL. Backhoe is MUCH nicer, for obvious reasons.
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A55315)
2023 Kubota U48-5...
Toro GreensMaster 1600 Walk-Behind Reel Mower (A55787)
Toro GreensMaster...
TAKEUCHI TL10V2 SKID STEER (A52707)
TAKEUCHI TL10V2...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2018 Ford F-150...
72" ROCK BUCKET (A52706)
72" ROCK BUCKET...
2012 Infiniti QX56 SUV (A55853)
2012 Infiniti QX56...
