Posthole Digger m59 with posthole digger on backhoe (and rock rake up front)
   / m59 with posthole digger on backhoe (and rock rake up front) #11
Charles,
Thanks buddy!
Charles,
By QCS do you mean the quick connects? I'm about to rig up a log splitter to my hoe and I was wondering if I had enough flow to run it off the thumb lines. It's gonna be a 4 or a 4.5 inch cylinder, and it calls for 11gpm. Cutting it close I suppose.
How much are the QA bucket ears?
-Mark
Yeah, I think the pioneer quick connects have a max flow of 12. Why run it off the thumb - do you have any other remotes? I find the front remotes REALLY useful if you don't have them, as you can run a lot of bobcat stuff - basically makes it into a big skidsteer. I'd tend to put the splitter on a FEL QA blank for ease of movement too.
Why? :confused: I dig full depth all the time with my 2 footer.
Yeah, I could dig that - big oak roots and boulders though I doubt. Its really convenient to have the auger on the hoe, but you lose a lot of horsepower by doing so - I forget the math, but I bet I'm running the auger off 1/3 the hp you are effectively (W.A.G)
   / m59 with posthole digger on backhoe (and rock rake up front) #15
Charles,
No, I don't have rear remotes. :mad:
I thinks its about 2k to add them or so. So I was figuring I could put quick disconnects to the thumb rod and use that instead. Are the factory also limited to 12GPM (i.e. are they pioneers)?
   / m59 with posthole digger on backhoe (and rock rake up front) #16
Charles,
Once you make a few holes you will really like that setup, I have a similar unit on my 110tlb and it works well.
   / m59 with posthole digger on backhoe (and rock rake up front) #17
This past weekend I just picked up a Mcmillen X1475 for my 110 tlb. Right now it is setup with a SSQA to go on the front loader, and the couple of "new toy" holes I dug with it went great, much better than a 3 pt hitch type I used before and I won't even mention how much better than digging by hand!!!
Have you guys ever used a hyd phd on the loader also? I am just wondering how it compares to on the backhoe? I need to line up some fun projects for winter, so is it worth making the swap? I would be making the mount myself.
   / m59 with posthole digger on backhoe (and rock rake up front) #18
Dude- I'm soooo jealous! I would love to have that setup. I'm about to dig about 150 or so holes for a horse fence and man that setup would be sweet!!! Very nice looking rig!
   / m59 with posthole digger on backhoe (and rock rake up front) #19
popped for RFB.
I've been using the 2 foot auger to punch tree and hydrange holes. Its a planting machine (pun intended) wife and I got 6 3 gallon hydranges planted in untouched forest soil in around 15 minutes - longest thing was moving the machine.
Be tough to go over a foot or 2 down with the 2 footer - think the 9" would do a lot better but haven't tried it yet
You can actually dig a foot or two with that thing? What, no rocks where you live? I'm fairly sure that I could never use an auger for anything.
Your machine does look pretty nasty. I am kind've surprised that you can run that rake up front though - I would've thought that 15gpm isn't enough.
JayC
Yeah, came rigged for the FEL. Backhoe is MUCH nicer, for obvious reasons.
Pig Statue (A55853)
Pig Statue (A55853)
2008 Toyota Camry LE Sedan (A55853)
2008 Toyota Camry...
2017 Yamaha VX1050B Deluxe Jetski (A50324)
2017 Yamaha...
43029 (A51691)
43029 (A51691)
UNUSED 1RANCH 1REAS WOOD GRABBER (A57193)
UNUSED 1RANCH...
2019 Genie GS-3232 32ft Electric Scissor Lift (A53421)
2019 Genie GS-3232...
