Tree damage, what is the cause
   / Tree damage, what is the cause #1
Code54
Elite Member
Putnam Co. West Virginia
Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
Was down in the woods today and ran across this tree. The damage goes up almost 8 ス- 9 feet on the tree. The tree is dead but I did not find any insects in the wood, nor any tracks around the bottom.
I was thinking maybe a black bear (know there is one running about) but didn't see any tracks or claw marks so I was looking for other ideas?
   / Tree damage, what is the cause #2
Appears to be dry rot. Tree has been dead for a long time. Rotting out from the inside. Possibly termites have had a good meal.
   / Tree damage, what is the cause #3
Could possibly be one of the smaller woodpecker species (Downy, Hairy etc)...
The debris pile looks like what a larger woodpecker leaves but they also would leave signs in the trunk...
   / Tree damage, what is the cause #4
+1 What he said.
   / Tree damage, what is the cause #5
Seems similar to damage I've seen from Pine Beetles (in pine trees) in Mississippi and Colorado.
   / Tree damage, what is the cause #6
Probably wood peckers, but I have seen similar damage lower down on a tree from raccoons and possums tearing the wood apart to get at bugs. They both leave sizable chunks.
   / Tree damage, what is the cause #7
The three vertical trenches in the trunk and chips below look similar to the work of pileated woodpeckers. In wood that soft, that is not a long job for a pileated woodpecker. :D
Thanks - we have a LOT of woodpeckers so that would make sense. It is also very dry and rotted so the two together maybe the cause.
When I first seen it from a distance I was thinking our resident bear got to it but when I got closer that got ruled out so I was at a loss.
   / Tree damage, what is the cause #9
My suggestion also.
   / Tree damage, what is the cause #10
Wood peckers go after bugs, worms that are found in diseased/infested trees. They do us a service by attacking the bugs. When they tear into a tree- the tree has already been dead for sometime.
2013 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A52128)
2013 Doyle Dry...
2003 JOHN DEERE 350D OFF ROAD DUMP (A51242)
2003 JOHN DEERE...
2020 FREIGHTLINER CASCADIA SLEEPER (A51222)
2020 FREIGHTLINER...
2013 INTERNATIONAL 4300 26 FT BOX TRUCK (A51222)
2013 INTERNATIONAL...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
2025 LandHonor DH-22-72W 84in Disc Harrow Tractor Attachment (A49462)
2025 LandHonor...
