Tree damage, what is the cause
   / Tree damage, what is the cause #1
Code54
Elite Member
Putnam Co. West Virginia
Kubota MX5100, Kubota BX25D,1957 Farmall Cub Lo-Boy Kubota KX91-3, BCS 853
Was down in the woods today and ran across this tree. The damage goes up almost 8 ス- 9 feet on the tree. The tree is dead but I did not find any insects in the wood, nor any tracks around the bottom.
I was thinking maybe a black bear (know there is one running about) but didn't see any tracks or claw marks so I was looking for other ideas?
   / Tree damage, what is the cause #2
Appears to be dry rot. Tree has been dead for a long time. Rotting out from the inside. Possibly termites have had a good meal.
   / Tree damage, what is the cause #3
Could possibly be one of the smaller woodpecker species (Downy, Hairy etc)...
The debris pile looks like what a larger woodpecker leaves but they also would leave signs in the trunk...
   / Tree damage, what is the cause #4
+1 What he said.
   / Tree damage, what is the cause #5
Seems similar to damage I've seen from Pine Beetles (in pine trees) in Mississippi and Colorado.
   / Tree damage, what is the cause #6
Probably wood peckers, but I have seen similar damage lower down on a tree from raccoons and possums tearing the wood apart to get at bugs. They both leave sizable chunks.
   / Tree damage, what is the cause #7
The three vertical trenches in the trunk and chips below look similar to the work of pileated woodpeckers. In wood that soft, that is not a long job for a pileated woodpecker. :D
Thanks - we have a LOT of woodpeckers so that would make sense. It is also very dry and rotted so the two together maybe the cause.
When I first seen it from a distance I was thinking our resident bear got to it but when I got closer that got ruled out so I was at a loss.
   / Tree damage, what is the cause #9
My suggestion also.
   / Tree damage, what is the cause #10
Wood peckers go after bugs, worms that are found in diseased/infested trees. They do us a service by attacking the bugs. When they tear into a tree- the tree has already been dead for sometime.
2018 RoGator 1100C (A51039)
2018 RoGator 1100C...
3in Poly Pipe (A49461)
2018 PJ  30+5 GOOSENECK TRAILER (A50854)
2018 PJ 30+5...
RIMS AND TIRES (A50854)
RIMS AND TIRES...
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2007 FREIGHTLINER COLUMBIA SLEEPER (A51222)
2007 FREIGHTLINER...
