Tree damage, what is the cause
   / Tree damage, what is the cause #11
Agree with the woody woodpecker theory. The chunks on the ground look exactly like pileated work.
Pretty neat - thanks for info -I learned something new!
   / Tree damage, what is the cause #13
Some pics I took today of Pileated woodpecker work. It (or they, there is usually a breeding pair for one large area) started on this tree early last week. Around here, if they work on a tree, you can be sure it has black ants in it, so they are not ruining a good tree normally.
Depending on the size of the ant infestation and the number of holes made, the tree may seal itself with sap and continue living. I doubt this tree will recover.
You can see the ant colony chambers in the heartwood.
They can make lots of holes as long as there are ants to eat.
The tree is alive, 40-45 foot tall and relatively healthy looking. The sweep in the trunk means it was stressed in some way or other during its life. That may have provided the opening for the ants. I'm not sure how the ants choose their trees. I've found them in both hard and soft wood species. It is quite a sight to see the ants come boiling out when you cut through a large colony with a chainsaw.
Wood chips. You can see a few exploratory holes. I don't know if the ants are detected by the resonance of the wood changing due to the ant colony voids, or by taste maybe?
Chapstick for size scale.
   / Tree damage, what is the cause #14
It amazes me that the 'peckers can hear the ants to know where to attack. Absolutely fascinating.
   / Tree damage, what is the cause #15
The three vertical trenches in the trunk and chips below look similar to the work of pileated woodpeckers. In wood that soft, that is not a long job for a pileated woodpecker. :D
Yep...that would be my guess. A pileated woodpecker is like a chainsaw with wings......and a REALLY hearty laugh ! :D
Wow that is impressive. Never really knew much about woodpeckers so this is really interesting.
THANKS for the info and photos!!!!!
   / Tree damage, what is the cause #17
   / Tree damage, what is the cause #18
You are welcome. Just a coincidence that they are working that tree over near the end of our driveway where I noticed it.
Pileated woodpeckers are crucial to woodland cavity dwellers and nesters. I believe they are responsible for the majority of tree cavities in this area.
Caterpillar 730 Articulated Dump Truck (A49346)
Caterpillar 730...
INGERSOLL RAND 100KW GENERATOR (A50854)
INGERSOLL RAND...
2021 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A49461)
2021 Ford F-250 XL...
2015 MACK GU 713 (A50854)
2015 MACK GU 713...
2025 Swict 84in Bucket Skid Steer Attachment (A50322)
2025 Swict 84in...
1969 JOHNSON J25 GOOSENECK TRAILER (A51222)
1969 JOHNSON J25...
