Transmission problem
   / Transmission problem #21
Mine definitely only runs when the tractor is running...and sometimes not even then hahaha.
Shortly after I first got my Kama, the entire instrument panel did not work for a couple months until I traced it to a loose ground connection at the head lights! So I lost at least 35 - 40 hours on the meter...maybe more? It is also the rpm tach sensor type. That is, it registers less hours when running less than rated rpm in the "green" zone. Because I run the tractor mostly between 1200 to 1700 rpm, in reality, I have many more actual hours on the tractor than the clock says.
   / Transmission problem #22
greg_g said:
Not on mine. Have you checked your wiring?
//greg//
No, didn't know any different until now! It worked like that since it was new when I bought it. It doesn't bother me though, it appears to keep the hours right - I just double check to make sure I cut the key to the OFF position. One of these days I'm going to re-do some of these harnesses but for now they will do.
   / Transmission problem #23
Is there a simple inexpensive aftermarket hour meter I could purchase and mount on the tractor?
   / Transmission problem #24
Sorry ECRob, I don't know for sure, but my guess would be yes. I'd check with an automotive, truck or tractor place. Maybe start with a Napa parts store? Or check online for something that works on your tractor.
   / Transmission problem #26
Get a Hobbs meter from a place like napa or carquest..
Soundguy
1982 SHOP BUILT GOOSENECK 24 FT TRAILER (A58214)
1982 SHOP BUILT...
30' E-Z Trail Head Cart (A59814)
30' E-Z Trail Head...
MASSAGE CHAIR (A58214)
HITACHI EX550LC EXCAVATOR (A58214)
HITACHI EX550LC...
1999 Featherlite Gooseneck Livestock Trailer (A59814)
1999 Featherlite...
2015 TROXELL 130BBL STEEL (A58214)
2015 TROXELL...
