transmission help
/ transmission help #1
magtop
carmichaels pa.
cub cadet 1054
Hello.first time writing in. Need help with replacing the hydro gear or transmission in a sltx 1054. Does some one know what other tranny or hydro gear will work it this mower. Thank you. Ps. The hydro gear is a 618-04270b.
/ transmission help
Thank you for info but I have a hydro gear and it doesn't have a filter and is different then an tuff torque.
/ transmission help #4
might try giving hydrogear tech support people a telcon - check their website for phone numbers..
also - if tranny is not mechanically damaged - might just remove from tractor - turn upside down - let old oil drain out (catch it all so you know how much came out - will take a day or so for old oil to drain out completely) -refill with fresh oil (hydrogear website should tell you oil specifics) - remount - run thru an air purge cycle. above all - WORK CLEAN! - no dirt,etc. allowed into tranny cavity. take pixs during disassy so as to know how to put back together right.
Good luck.
Aluminum Set of Tool Boxes (A62613)
Aluminum Set of...
Timberjack 608B FellaBuncher (A62679)
Timberjack 608B...
2015 Ford F550 4x4 with 37' Bucket (A62613)
2015 Ford F550 4x4...
1994 CHEVROLET GMT-400 EXTENDED CAB TRUCK (A64280)
1994 CHEVROLET...
1999 Fruehauf (A64127)
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
