transmission help
/ transmission help #1
magtop
carmichaels pa.
cub cadet 1054
Hello.first time writing in. Need help with replacing the hydro gear or transmission in a sltx 1054. Does some one know what other tranny or hydro gear will work it this mower. Thank you. Ps. The hydro gear is a 618-04270b.
/ transmission help
Thank you for info but I have a hydro gear and it doesn't have a filter and is different then an tuff torque.
/ transmission help #4
might try giving hydrogear tech support people a telcon - check their website for phone numbers..
also - if tranny is not mechanically damaged - might just remove from tractor - turn upside down - let old oil drain out (catch it all so you know how much came out - will take a day or so for old oil to drain out completely) -refill with fresh oil (hydrogear website should tell you oil specifics) - remount - run thru an air purge cycle. above all - WORK CLEAN! - no dirt,etc. allowed into tranny cavity. take pixs during disassy so as to know how to put back together right.
Good luck.
iDrive TDS-2010H...
New/Unused Landhonor 8ft x 10ft Galvanized Apex Roof Metal Shed (A65583)
New/Unused...
213088 (A64276)
213088 (A64276)
20' CONNEX BOX (A65643)
20' CONNEX BOX...
JOHN DEERE 300P EXCAVATOR (A65053)
JOHN DEERE 300P...
John Deere 6320 (A64126)
John Deere 6320...
