transmission help
/ transmission help #1
magtop
carmichaels pa.
cub cadet 1054
Hello.first time writing in. Need help with replacing the hydro gear or transmission in a sltx 1054. Does some one know what other tranny or hydro gear will work it this mower. Thank you. Ps. The hydro gear is a 618-04270b.
/ transmission help
Thank you for info but I have a hydro gear and it doesn't have a filter and is different then an tuff torque.
/ transmission help #4
might try giving hydrogear tech support people a telcon - check their website for phone numbers..
also - if tranny is not mechanically damaged - might just remove from tractor - turn upside down - let old oil drain out (catch it all so you know how much came out - will take a day or so for old oil to drain out completely) -refill with fresh oil (hydrogear website should tell you oil specifics) - remount - run thru an air purge cycle. above all - WORK CLEAN! - no dirt,etc. allowed into tranny cavity. take pixs during disassy so as to know how to put back together right.
Good luck.
Ficklin 435 (A64127)
2018 DODGE RAM 5500 FLAT BED TRUCK (A65643)
2018 DODGE RAM...
For Sale - Brush Hog - Woods RCC42 rotary cutter
For Sale - Brush...
Pallet of 3 Large Electric Motors (A62679)
Pallet of 3 Large...
iDrive TDS-2010H...
Kubota MX6000 (A64126)
