Trans knocking, no reverse.
/ Trans knocking, no reverse. #1
Spyderhd
Sedalia Mo
TYM T350
I have a TYM T350 with 220 hours on it. It will not move in reverse, and makes quite a racket moving forward. When I neutral, with the clutch out, there is a pretty loud knock coming from the trans. I have tried 2 wheel and 4 wheel drive with the same results. I expect this is a major failure, but am hoping for a possible easy fix. Just out of warranty as well. Please let me know if you have any ideas at all!
Thanks
Andrew
/ Trans knocking, no reverse. #2
I have a TYM T350 with 220 hours on it. It will not move in reverse, and makes quite a racket moving forward. When I neutral, with the clutch out, there is a pretty loud knock coming from the trans. I have tried 2 wheel and 4 wheel drive with the same results. I expect this is a major failure, but am hoping for a possible easy fix. Just out of warranty as well. Please let me know if you have any ideas at all! Thanks Andrew
Sounds like something broke or fell apart. Not good.
I would agree! Sounds expensive to be honest. Was looking at it trying to determine how to drop the trans. Does not look too easy.
/ Trans knocking, no reverse. #4
Is the noise there when in neutral and tractor not moving at all?Is this hydro or gear driven?
John Deere Decorative Metal Sign (A61569)
John Deere...
2006 HONDA RANCHER ATV (A62130)
2006 HONDA RANCHER...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A62131)
UNUSED RAYTREE...
2013 Ford F-150 Pickup Truck (A61568)
2013 Ford F-150...
2015 Isuzu NPR 16ft. Box Truck (A61568)
2015 Isuzu NPR...
2004 International 4400 Flatbed-Dump (A62613)
2004 International...
