Trans knocking, no reverse.
/ Trans knocking, no reverse. #1
Spyderhd
Sedalia Mo
TYM T350
I have a TYM T350 with 220 hours on it. It will not move in reverse, and makes quite a racket moving forward. When I neutral, with the clutch out, there is a pretty loud knock coming from the trans. I have tried 2 wheel and 4 wheel drive with the same results. I expect this is a major failure, but am hoping for a possible easy fix. Just out of warranty as well. Please let me know if you have any ideas at all!
Andrew
/ Trans knocking, no reverse. #2
I have a TYM T350 with 220 hours on it. It will not move in reverse, and makes quite a racket moving forward. When I neutral, with the clutch out, there is a pretty loud knock coming from the trans. I have tried 2 wheel and 4 wheel drive with the same results. I expect this is a major failure, but am hoping for a possible easy fix. Just out of warranty as well. Please let me know if you have any ideas at all! Thanks Andrew
Sounds like something broke or fell apart. Not good.
I would agree! Sounds expensive to be honest. Was looking at it trying to determine how to drop the trans. Does not look too easy.
/ Trans knocking, no reverse. #4
Is the noise there when in neutral and tractor not moving at all?Is this hydro or gear driven?
2015 WINSTON TANDEM AXLE 24FT EQUIPMENT TRAILER (A66091)
2015 WINSTON...
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
2011 FORD CROWN VICTORIA POLICE CAR (A66091)
2011 FORD CROWN...
2015 Ford F-150 Crew Cab Pickup Truck (A66736)
2015 Ford F-150...
2018 MAGNUS MINI VAC TRAILER (A67714)
2018 MAGNUS MINI...
1997 FRAC TANK 500BBL WHEELED (A68842)
1997 FRAC TANK...
