Trailer
/ Trailer #11
Last year I built a trailer that turned out to be fairly handy. It is a tiltdeck with tailgate. It has 14 inch wheels and is 5x101/2 feet. I built the sides high enough to be able to put a plastic 5 gallon gas can in and close the top. The top, which is as long as the trailer, folds down to create a flatbed above the main floor. This is really handy as you can put your gear in, close the sides down and load your atv on top. Also I put an extra set of hinges on the right side so the folding side can be slipped off and back on at the top to create a table to the side of the trailer. If you would like some pics I will put them on for you. The other thing is that I used a jack that I can pull a pin and rotate the whole of the jack in line with the trailer frame so it doesn't interfere with the pickup tailgate. The top can also be partially closed so a tarp can be thrown over to keep things dry or make a sleeping area.
Morgan 26ft Box Truck Body (A59230)
Morgan 26ft Box...
2018 Ford F-150 4x4 Crew Cab Pickup Truck (A59230)
2018 Ford F-150...
2020 INTERNATIONAL REEFER TRUCK (A58214)
2020 INTERNATIONAL...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2011 ORTEQ TANK MANIFOLD (A60736)
2011 ORTEQ TANK...
UNUSED FUTURE 16" HYD AUGER (A52706)
UNUSED FUTURE 16"...
