Trailer?
/ Trailer? #51
td, get a 17' trailer , tand. axle. I got a 755 with loader, and when you put something on 3ph, you will use up all that room. Thats the setup I got. make sure you get trailer brakes with that little truck of yours. You tractor is only 1 size biugger than mine, but doesnt really weigh that much more. Trust me.,.....17' will fit that tractor. And will be around when you upgrade your truck. You can also haul gravel/sand/mulch/dirt etc with side rails.
/ Trailer? #52
Haven't heard anyone mention the use of load leveler or stabilizer arms, that appear to be commonly used on camper trailers. We started using these when I was a kid, on the camper, and I would think they would be great for any sort of heavy trailer. I've seen many rigs around here, sagging in the back, even though they we not overloaded. That kills steering, handling, and braking in the front.
For those who don't know (maybe some one could put up a pic or better explanation), the stabilizers are usually slender solid steel pieces about 1" or so square, about 30" or so long. They bridge between either side of the receiver hitch (you need a special hitch with the "sockets" to accept the stabilizers), and back to the trailer tongue frame on each side, where they are tensioned in the same way a chain binder is. The solid mounting at the receiver, and upward tension back along the tongue, forces the tongue/hitch/truck frame up into alignment, and puts more load on the front axle. I'm told it's possible to put enough force on the stabilizers that you can actually reduce rear traction, if the ball is too low to start with.
Once properly adjusted for the truck/trailer, they are very easy to put on and pull up. Can anyone give more detail on these, and possibly any problems or concerns? I'd think a lighter truck, like the Toyota, would benefit greatly from them.
/ Trailer? #53
My dad has a sway control hitch system by Reese. Their website offers some good info
<A target="_blank" HREF=http://www.reeseprod.com/>http://www.reeseprod.com/</A>
/ Trailer?
Thanks woody,
I am searching as we speak. I am ready to take my tractor show on the road.
/ Trailer? #55
Thanks, gobbler
<A target="_blank" HREF=http://www.reeseprod.com/info/info/img/wd_info_callouts.gif>Here's</A> the specific system I was talking about. I'm gonna put one on my trailer (when I get it).
/ Trailer? #57
Reese, I think, used to advertize equalizer hitches by pulling a trailer around to shows behind an Olds Toronado. The Toro didn't have rear wheels and tires, the trailer, through the hitch, carried the rear of the car.
/ Trailer? #58
Mark,
Good point. I have used the reese system with a 23 foot wilderness camper and the difference is amazing in terms of how the trailer handles behind the tow vehicle. I now tow with a Suburban and the hitch indicates a greater towing capacity with a "equalizer hitch". I'm not positive but I believe there is about 30 % more towing capacity. I have not used it with my 16 foot tandem axel trailer that I tow my tractor with as I didn't feel it was necessary. My calculated weight with trailer,tractor and loader is less than 5000 lbs. It definetly makse a positive difference.
/ Trailer? #59
I noticed a jeep GC pulling a tractor! Can I do that with my cherokee? How can I figure out the tongue weight and how much it will hold or pull? Whenever people talk about weight and traveling why is it allways hyrogliphics to me?
/ Trailer? #60
The Jeep Operators Manual should have that information in it.
2000 Peterbilt 378 Tri-Axle Dump Truck (A59230)
2000 Peterbilt 378...
2015 Jeep Patriot SUV (A59231)
2015 Jeep Patriot...
2002 Bobcat 863 High Flow Compact Wheel Loader Skid Steer (A59228)
2002 Bobcat 863...
Utility Cart (A59231)
2006 GMC C5500 BUCKET TRUCK (A59906)
2006 GMC C5500...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
