Trailer Weight Distribution Question
/ Trailer Weight Distribution Question #1
EastTnFarmboy
East TN
Kubota L5240 ROPs FEL, JD LX277, Ferris 3100Z
There are several threads on this site where proper distribution of weight on a trailer is discussed. In general, it seems that in order to avoid "porpoising" and other trailer control problems the weight should be as close to the front of the trailer as possible without exceeding the appropriate tongue weight. As has been discussed in other threads, sometimes it takes a while to find that certain "sweet spot".
This morning I was working with a loaded utility trailer and noticing how heavy the tongue was in comparison to a trailered boat of approximately the same weight. I started pondering the fact that with most boats, a majority of the weight is in the rear because of the design and the fact that the motor is in the rear.
I am sure it is a simple reason that I am just overlooking, but why do you not experience control problems when pulling a boat where the weight is distributed toward the rear instead of as far forward as possible? If it is merely trailer design, what makes it work?
There is no overwhelming reason I need to know, I am just curious. I'm sure that some of you who are much more knowledgeable than me can explain this.
Thanks!!
/ Trailer Weight Distribution Question #2
If you really look at a boat trailer,whether it's a single, tandem, or tri-axle in design, the axles are placed well back on the trailer so as to support the center of the the load, not necessarily the center of the boat
/ Trailer Weight Distribution Question #3
Look at where the axle(s) is located in relation to the extreme ends of the trailer/ load combination. It will be well behind the 50% point. Simply put, moving the axle to the rear puts more of the total weight on the coupler ball. The design axle placement takes into consideration the weight distribution of the type of boat that the particular trailer is designed to haul.
/ Trailer Weight Distribution Question #4
Boat trailers tow well with only 5% tongue weight. Utility/RV trailers need 10-15%. It's the length of the trailer tongue and weight concentrated closely over the trailer wheels that does it. Utility trailers have a short tongue (tongue tied?) and variable types of load distribution. Boat trailers ensure the boat is loaded in an identical fashion each time. I think of a lever arm/fulcrum diagram.
My Continental Cargo utility trailer owners manual states a "bumper pull" type of trailer should have a 60/40 weight distribution front to back, with the dividing point a line drawn in the middle of the wheel (or wheels if tandem axle). They say a gooseneck/5th wheel trailer should be loaded 70/30.
/ Trailer Weight Distribution Question #5
In my experience if you need load distribution hitches you dont have enough truck. I hauled 14,000 on my receiver and never had problems went right down the road no sway. Though I dont play went it comes to towing I own a Ford dually.:D
/ Trailer Weight Distribution Question #6
Not to nit pic but you didn't mention what Ford dually you own. According to the Reese Hitch website a 2007 or 2008 F350,450, or 550 with a class 5 hitch is only rated to tow 12000# with 1200# of tongue weight or up to 17000# and 1700# tongue weight but only with a weight distribution hitch. The manufacturers hitch rating along with the vehicles maximum tow rating is what sets the amount of weight you can tow. Anyone can mount a class 5 hitch on a Ranger but that doesn't mean the Ranger can tow 12000#. I'm sure you're dually could tow more but you are stressing the hitch by going over the mfg. specs which are stamped on the hitch.
/ Trailer Weight Distribution Question #7
OK sorry but one is an 82 flatbed it will out haul my 97 dually the 82 is my project truck its in the plans to get a 6v92 detroit one day. but any way one is a 82 and the other is a 97 crew cab. i will put pics on here once i figure out how to make a pic profile.
/ Trailer Weight Distribution Question #8
I have ran into this many times. A one ton is not a one ton. I have a 2006 F-350 4x4 Powerstroke and the GVWR is 11,400# . My neighbor has a 2007 GM 3500HD 4x4with the Diesel and Allison. His GVWR is 9,900#. Thats 1,500# difference. He used to use my 2004 F-250 4x4 Powerstroke to pull his trailer from time to time, its rated at around 10,500#, and it handles the weight much better than his new GM. I never realized there to be that much difference but there is. Lesson is look at what spring package it has before buying. All my truck are extend cab short beds so they will fit in the garage. His truck is a 4 door long bed bus. Anyway we went to get firewood last week and mine did not squat a bit, his on the other hand was sagging good. Granted he has a slightly bigger bed but we had about the same load in the trucks.
Chris
/ Trailer Weight Distribution Question #9
When I load a heavy weight on a trailer, I look at where the bumper is in relation to ground and I load it on and I make sure that I have the back of truck a little lower than it was and all works just fine without playing with a scale
and if you look at my avatar with a 14K trailer with a 6,500 skid steer on it, it sets level and fine. And NO I do not take that on the road, I was just playing with my toys :D
Jim
/ Trailer Weight Distribution Question #10
Jim
Same thing for me, with different implements on my tractor I have to vary exactly where I place it on the trailer and it only takes just several inches either way to make a big difference. I watch the squat of the truck as I'm loading to get it close, then a good indicator is to look at distance between the body to axle bumpers under the truck - you need a few inches clearance minimum for suspension travel. Mine has a good 3" or 4" clearance when loaded. My trailers run nice and level at proper tongue weight - my dump has an adjustable coupler and I use a 6" rise ball mount to have my equip. trailer level with the tractor on it, it's a fixed coupler.
/ Trailer Weight Distribution Question #11
LOL, I cheated, I bought a set of air shocks and I just love them.
Makes my little baby truck haul the loads that the big boys do, I bought a set of pallet forks with attachment plate and when they loaded them on the rear of my little S-10, it did not go down very much for ? 500 pounds behind the axle :D
and it worked great.
Jim
/ Trailer Weight Distribution Question #12
Jim
Well you can't cheat Mother Nature or a Semi-Floating Axle with Too Much Weight...
S-pickups
GM 7.5-in. (SF) GM 7.25-in. (ICA)
The 'semi-floating' axle is one where onto the axle shaft is 'pressed' a bearing -- and that axle itself has studs for the mounting of the wheel on that end -- and splines to go into the 'spider gears' of the differential carrier on the other. In this form, the axle bears the weight of the vehicle via the bearing which is located in the axle 'housing' close to the flange which holds the wheel.
When hauling large loads, this is what you want...:D
A 'full floating' axle is one in which the hub (onto which the wheel is bolted) is supported by bearings; and the axle shafts are then connected (in our case pushed from the outside towards the differential carrier (aka 'pig' or 'chunk' or 'gearset'). No actual weight is borne by the axle shafts -- which are merely used to transmit torque from the 'rear end' gears to the 'wheel-end'.
/ Trailer Weight Distribution Question #13
You're missing the point of weight distribution hitches. The point is not to make the load "level". The point is to re-distribute the weight so that more of it is pushing down on the steering axle, where 80% of your braking is.
Doesn't matter if it's an f-250, 350, 450 etc. If you hang 5,000 pounds off the back bumper...that makes the front end light. If the front end is light, the truck won't steer or brake properly. The gooseneck or 5th wheel eliminates (mostly) the problem, because no leverage is gained with the weight over the axle...as opposed to hanging off the bumper.
/ Trailer Weight Distribution Question #14
Chris
couldnt agree more. My crew cab short bed has a 10,000 lb gvwr and a sticker that says max cargo 2400lbs
2018 Sundowner FD-306 REV A 24ft. T/A Enclosed Gooseneck Trailer (A64194)
2018 Sundowner...
John Deere Forks (A64126)
John Deere Forks...
72" Maxilator Grapple MBD (A64127)
72" Maxilator...
2000 Yale GLC030A 2,500lb Propane Foklift (A61572)
2000 Yale GLC030A...
2000 GMC W3500 Cab and Chassis Truck (A59230)
2000 GMC W3500 Cab...
YANMAR VIO35-6A EXCAVATOR (A64279)
YANMAR VIO35-6A...
