LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 12,412
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
Yes, it factored into my trailer purchase quite a bit. It's a deckover power tilt in aluminum so only 2600 pounds for the trailer.LouNY,
Be careful with where you haul with that combination with truck rated pull of 11K and trailer gross rating of 14K. State troopers have a pretty good idea of what truck is rated to pull what load and you may get a serious looking over. DOT fines get expensive fast. The trailer, depending on type could be 4K Lbs ( my 14K dump trailer weighs 4K ) leaving you only 7K of legal load. Depending on what your hauling that could be as little as 2- 2.5 yards of gravel if your 14K is a dump trailer.
As for regulations as long as I'm not over my trucks axle load ratings or the trucks GVWR and the trailer load doesn't exceed the 11,000 pounds it's not an issue.
Also very seldom will I have more then 7-8000 pounds of load.
I did anticipate a heavier truck in a year or so. So then the truck will be a 10,000 gvwr and a 14,000 trailer still keeps me under the 26,000 that can be a worry. Also none of my hauling is for commercial purposes or hire or profit.
Plus often I can fall back on the right to farm laws and farm regulations.
Also I went with the 14K rated trailer for the axles, the dealer registered it for the 14K, I think that I'll go in next year and register it for 12,000, unless I've swapped trucks by then.
