Trailer warning, this could happen to you
   / Trailer warning, this could happen to you #71
I’ll tell you this, ever since I found and removed the tiny screw, no more wacky trailer brakes.
That could have been a disaster. Once you slide back the cover and look at the guts of your trailer plug, you can see how easily this could happen.
I was thinking of using Loctite.
I would use Loctite before I used any other suggestions listed on here. Not that they do or don't work, but with my thoughts, Loctite is used to lock screws, whereas the other items "may or may not" accomplish what you are trying to do, and "IF" a wire got loose, which increases resistance, which causes heat. Now "just IF" the stuff you are putting in contact with the heat source happens to be an item that will burn and you have pressed it up against a heat source... HOW COULD THAT GO WRONG?
The silicone or the other stuff isn't designed to keep the screws tight, which is where the problem started.
David from jax
   / Trailer warning, this could happen to you #72
I borrowed my nephews equipment trailer and the plug had been dragged and ruined.
Since I already have spares on hand I replaced his plug, then the fun began. Someone had spliced a turn signal wire with a different color, and I'd followed the color code (now 2 red wires) for a 7-pin Bargman plug.
Often a VOM is invaluable.
   / Trailer warning, this could happen to you #73
And a few minutes checking the actual working featues of the trailer once you have it wired and ready to go! There is a lot to be said about doing a pre-trip inspection on a trailer (and tow vehicle!)
David from jax
   / Trailer warning, this could happen to you #74
I have some 30ft test leads with alligator clips on each end. It was a give me from Matco a couple years ago in a Christmas giveaway.
If i'm running into an issue where someone got creative with wiring, I'll break out those leads and my ranger test box.
I'll hook the ground lead to ground on the battery and the ground wire in the harness.
Then start running power to each of the other wires in the plug to see which light comes on
Definitely beats tracing wires.
   / Trailer warning, this could happen to you #75
There are so many factors to consider and put together, for my 2" ball mount I'm using a Draw Tite drawbar rated for 16,000 pounds with a 2" ball rated for 12,000 pounds.
My RAM with the 2" receiver is rated for a bit over 11,000 pounds.
My new trailer is rated for 14,000 pounds GTW on a 2 5/16" ball and seeing as how I could easily get to the upper limits I got a kind of fancy drawbar which is rated for a little less then the trailers max GVW but more then the truck is rated for. It's a Weigh Safe rated for 12,500 pounds with a built in scale for the tongue weight.
Have the same setup and love it!
   / Trailer warning, this could happen to you #76
Of course my new truck has the 2 1/2" receiver so now the question is do I just use the adapter sleeve or a new hitch to match the trucks capabilities :)
Which kicks me up to a max trailer of 18,230 pounds.
   / Trailer warning, this could happen to you #77
You will never be happy with that adapter sleeve rattling around!
Resistance is futile, you must get a new hitch.
   / Trailer warning, this could happen to you #79
You got a newtruck?
(y)
2005 Autocar WXR Heil Rear Loader Garbage Truck (A55852)
2005 Autocar WXR...
2011 Mercedes Benz S-Class Sedan (A55758)
2011 Mercedes Benz...
Manac Walking Floor Trailer (A50322)
Manac Walking...
2019 Chevrolet Suburban SUV (A55758)
2019 Chevrolet...
Generac Yanmar 5000Watt Heavy Duty Diesel Generator (A54811)
Generac Yanmar...
2014 Jeep Cherokee Sport SUV (A55758)
2014 Jeep Cherokee...
