Trailer Towing question
/ Trailer Towing question #31
<font color=blue>You will be the one riding in the trailer</font color=blue> or at least sleeping in the doghouse/w3tcompact/icons/laugh.gif <font color=blue>push the brake & see if you get voltage at the connector. </font color=blue> I was guessing you'd need inertia to make the sensor send the voltage?
/ Trailer Towing question #32
Hazmat,
can you provide a link about the V-10. Couldn't find it. Marty
/ Trailer Towing question #33
You'll have that 427 sitting up front. With the "tongue heavy" trailer, you might want the engine and front wheels sitting a bit closer to the front trailer axle than the wheels do compared to the back trailer axle. Seems to me I read or saw where those Vette's were pretty close to 50/50 weight distribution. You could check that on one of the Vette web page forums.
the "X" placement of the straps will minimize side to side sway of the car on the trailer.
Be sure to check everything after 10-20 miles, just like when you drove semi's.
When they hook up the trailer, go over everything yourself too. I picked up a concrete buggy a couple days ago; the guy did'nt cross the safety chains. It was not a big deal, but if the trailer had come loose, the tongue would've hit the ground. If you cross the chains, it can act as a cradle for the trailer tongue if it comes off the hitch. Check the lights, and hitch connection, the safety chains, the breakaway wire. Check the tires. If something happens on the road, it is your resposibility as the driver.
Another idea a guy gave me is to use a locking cross pin for you reciever. He swore by it. He had one of the cross pins with the hole in it, and the hairpin retainer that goes through the hole. The hairpin came loose, allowing the crosspin to come loose. His crossed safety chains were all that saved the four horses in his trailer.
Check too to see if the trailer has a breakaway braking system. If the trailer brakes free from your truck, you want it to stop, not pass you.
It's actually a '65 which had the 396 engine rated at 425 horses. It was only offered for half the year and there were only 2500 or so made. In '66, in an effort to shave a few pounds off the car, the block was bored out to 427 cubes./w3tcompact/icons/wink.gif I'm not too sure about the small blocks but weight dustribution on the big blocks was aweful. If you want a car that handles, don't get a big block!
When I bought this hitch I attempted to find a locking pin for the receiver. Unfortunately the receiver is wider than standard being a class V and none that I found were long enough. Now that I think of it, I hope the hitch place has a weight distribution hitch that is the right size for my receiver. Oh well, at least I got the Prodigy all installed and ready to go.
On a good note, I found out today that I will not have to travel to Ohio from Charlotte, NC as originally expected. I am now taking the car to Knoxville, TN which cuts my driving distance by more than half. It will be a much more casual, relaxed trip.
Jeff
/ Trailer Towing question #35
Marty,
Well since the V-10 isn't listed on the web page I assumed it was discontinued. They do offer a 6.8L V-8.
<A target="_blank" HREF=http://www.fordvehicles.com/Trucks/superduty/features/specperformance/?featureId=2>Fordvehicles Superduty performance specs</A>
Too bad I promised the wife (under the penalty of death or divorce -- her choice) that my supercrew was going to last 10 years. That new diesel looks like fun.
/ Trailer Towing question #36
Well just found the 6.8L listed as a V-10 elswhere on the site/w3tcompact/icons/blush.gif. I guess quality isn't job 1 on the web site.
/ Trailer Towing question #37
Yes Ford will be continuing with the V-10. There are no immediate plans to discontinue it.
/ Trailer Towing question #38
Hazmat,
That must be a typo............those are the specs for a V-10.
If you do the math on the volume of each cylinderX8, you get somewhere around 330 CID, which is the same as the 5.8L.
Ford tried to reserve a lot of the V-10's for the Excursion, but since thats being discountinued......
Jerry
/ Trailer Towing question #39
Thank god. I love my QUIET non-fuel efficient V-10. It tows my trailer @ 10,000 lbs. quite nicely.Hope to get a new one in 2004 model year. Marty
/ Trailer Towing question #40
<font color=blue>"The guy at the place also told me to put my straps to the rear of the vehicle in an X so as to keep the car from moving side to side."</font color=blue>
Jeff,
I load and strap down a lot of vehicles each week. Whoever told you that was dead wrong. DO NOT cross your straps EVER!
At the very best you'll create a situation wherein you'll have them rubbing against one another creating wear and potential tear away problems. At worst you'll also have those straps rubbing against parts of the undercarriage which are lower than the axles. A sharp edge and a couple flexes of the suspension and your straps are cut. Even without anything that dramatic there is an increased potential of wear and tearing.
Your best bet is to run your straps at a low angle from each axle down to the tie down points and to have those tie down points located so that your straps run slightly outward from the attachment points on the axles.
MORBARK WOOD HOG 3400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
Unused 2024 AGT H15 Mini Excavator (A59228)
Unused 2024 AGT...
2016 Nissan Titan XD 4x4 Crew Cab Pickup Truck (A59230)
2016 Nissan Titan...
2018 International WorkStar 7500 Aquatech B-15 Combination Sewer Jetter Vacuum Truck (A59230)
2018 International...
INSPECTION (A61166)
INSPECTION (A61166)
5' MOWER (A52706)
5' MOWER (A52706)
