Trailer Tires Load Rating
/ Trailer Tires Load Rating #1
johnems
I am replacing some older tires on my dull axel 14000 lb. trailer. The current tires are a load rating G. I am told by two shops that you can no longer get G rated tires and you have to get F one step down. Does anyone know if this is true? Thanks John Morrissey
/ Trailer Tires Load Rating #2
They usually put E rated tires on a 14,000 pound trailer which are range from 3200-3400 pounds per tire at 80 psi (depending on the size and mfg.) Post the tire size and the load rating from the old tire for more info.
/ Trailer Tires Load Rating #3
I have had good luck with Hancook tires that are 14 ply rating, in a 16 inch trailer tire. All of the ranchers down here run these because they are narrow and stout, which means less pull and better fit on trailers. They take 105 PSI. The dealers say they are rated for tubes but they all mount them tubeless. I have had many sets over the last 8 years. I think the max load is 3330 lbs. They are made in Korea, and I think the rating is g or h.
rick
/ Trailer Tires Load Rating #4
JOHN DEERE 300P EXCAVATOR (A65053)
JOHN DEERE 300P...
1984 Charles Machine Works S4A S/A Tilt Deck Trailer (A61573)
1984 Charles...
2009 Blue Bird All American/ All Canadian School Bus (A61568)
2009 Blue Bird All...
NEW Wolverine 84" Skid Steer Bucket, 38" Depth (A62679)
NEW Wolverine 84"...
NEW Rachet Tie Downs and Flatpack Tool Box (A62679)
NEW Rachet Tie...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A63688)
2019 Krause...
