Trailer Tire Question.
/ Trailer Tire Question. #1
Krewz
Berks Co., Pa.
Kubota BX25
I bought a new dual axle lanscape trailer from Appalacian Trailer last July. The trailer has less than 2,000 miles on it and the right rear tire is bald. The other three tires are worn more than I think they should be, but still have about half the tread that the unused spare has. The date codes are all from early 2007 and the trailer is a 2010. The trailer is rated for 7,000 lbs. and weighs about 2,000 lbs. I only load it with my BX25 which is about 3,000 and usually without the BH and the FEL. Total weight is around 5,000 lbs. and 3,700 lbs. without the BH and FEL. so I know it's not overloaded. The tires are 225/75D-15 load range C.
I called the trailer manufacturer and told them that I thought the right rear wheel was out of alignment and they referred me to the tire distributer. The tire distributer asked me what brand of tires I had and I told them "MILEST" they said there is no such brand and I should call the trailer manufacturer.
After further examination, I saw that two letters were ground off of all five tires. The name should have read "MILESTAR".
I called Appalacian Trailer again and spoke with the production manager. He took all of my information and said that he will call me back tomorrow with a solution.
My question is, why do you think they would grind off the last two letters of the manufacturers name? It seems an angle grinder might have been used due to the curviture of the scratch marks.
Thanks in advance. :)
Krewz
/ Trailer Tire Question. #2
Do a google on milestar ST tires.
Probably one reason the letters were ground/cut off was these tires may have have had a recall some years back. Looks like the trailer manufacture has installed recalled tires which they can do as ST tires aren't a passenger carrying tire. Certainly unethical if thats what went down. Many P and LT tires were recalled.
You should be running trailer tires at max sidewall pressures.
This from a RV website;
"Posted: 09/18/08 09:18pm Link | Print | Notify Moderator
Hey folks,
I had noticed a small crack on the sidewall on 1 of my Milestar M-108 tires and contacted them a couple of weeks ago to see if they were on the recall list. They replied that they were not, but if I sent pics of the tire(s) in question they would determine if they'd send replacement(s). I've had the trailer for a little over a year and am wondering if the single crack is a sign of things to come (read a few posts here on the subject)?
Well, today I received and email from them with the following:
"Our Office can offer you with NO Charge Replacement Tires, to replace out the tires you are experiencing problems with. The tires would arrive to you within 3-5 business days..."
/ Trailer Tire Question. #3
i've seen many tractor tire dealers do that.
sell seconds or blems, and grind the tire name off.
soundguy
/ Trailer Tire Question. #4
Hey folks,
Sure wish Taskmaster would have stood behind their tires like that. I bought a 2008 Gatormade in January 2009 new. Last spring I noticed severe weather cracking in the tires. I called Gatormade and they agreed they shouldn't be doing it. Gatormade and I both contacted Taskmaster, but Taskmaster refused to do anything about it saying the tires are only good for 1 year and since they were made in July of 2008, they wouldn't do anything about them. I haven't replaced them yet, but the cracking is getting bad enough, that I'm going to have to do it real soon.
/ Trailer Tire Question. #5
Makes me wonder how we could build superior products like tires in American Plants 50 years ago and now there is so much junk out there.
/ Trailer Tire Question. #6
i hear ya.. i've got some trators with oem or at least.. very vintage tires on them. tey are dry and cracked and checked.. but heck.. 60ys???
and the tires on my horse trailer didn't even make it 8ys.. :)
soundguy
/ Trailer Tire Question. #7
Has nothing to do where they are made, its what they are made of. The EPA makes us take all the good stuff out of tires, paint, fuel, ect.
Chris
/ Trailer Tire Question. #8
I had this happen on a Tennessee Trailer. Turned out to be the U-Bolts were loose on the leaf-springs. When empty everything was tight because of the arch of the springs. When loaded the bolts were so loose I removed 14 of the 16 nuts with my bear hands.
Load your trailer down then tighten everything up. Go over each nut and bolt on the trailer. Mine ate tires just like yours did till I found out what was going on. Ate up 2 sets of tires in the mean time.
The issue is trailer manufactures have no quality control. Using a impact wrench to put them together is RED-NECK. Its fine to snug them up but you need quality control where a torque wrench is employed to assure everything is at spec. Heck, using a impact wrench it could be going south and say on day its set at 100 FT LB and the next day its at 65 FT LB and the following 30 FT LB before they realize the problem. In the mean time trailers have been shipped.
Chris
/ Trailer Tire Question. #9
Sometimes they put used tires on them to save you money or them. I bought my 7000lb carhauler with used tires on it. I knew it and told them that was fine. If i wanted i could have had new ones put on for another $200. I figured they would be dry rotted by the time they wore out. I just run used tires on it. For the 500 or less miles i put on a year i cant tell the tread even is wearing. Now that i have said that i will go to the closet and get out my asbestos suit.
I know im not the only one who does this let alone runs car tires on any kind of trailer with no problem. But im not towing 5000lbs of tools and bobcats everyday for a business either.
/ Trailer Tire Question. #10
I did the same thing. Got my trailer with used tires and they lasted 7 years. Spent the dime and got 4 brand new Goodyear Marathons in load range C put on and had 2 fail in about a year, go figure. Then bought 4 brand new Greenball Towmasters in 2007 with out a single issue.
Chris
/ Trailer Tire Question. #11
Chris
Some of the longest lasting tires I have are Nylon... at least that is what it says on the sidewall... no cracks at all and guessing from the 1960's.
They will take a "Set" from sitting that quickly goes away after a minute or so in CA mild climate... heard they could get really hard and stiff when it's really cold.
Thank you all for your responses.
I spoke with a guy from Appalachian today and he told me that they bought a truckload of tire/wheel combo's to install on a batch of "price point" trailers. I guess that means low cost? He said that they are not seconds and are indeed MILEST brand tires. I Googled MILEST and couldn't find them. He also told me that these tires do not have a warranty at all. He offered to sell me tire/wheel combo's for $70.00/per.
I have the one year warranty paper from when I bought the trailer. I hate the thought of small claims court, but what other option do I have?
If it worked, I attached a picture of the spare tire. Like the other four, you can see the name appears to have been altered.
It also appears that the cords are already showing on the side wall.
I have to wonder if they used "price point" parts anywhere else on the trailer.
:mad:
Krewz
Chris
Thanks Chris.
I'll do that this weekend. :thumbsup:
Krewz
/ Trailer Tire Question. #14
I have been in the trailer business and seen lots of shoddy things but this has to take the cake.
I would contact the better business bureau in the town that manufactures the trailers. I have done this twice, and both times gotten the results I wanted.
As for tire warranties, they are worthless. Its one of them things you just can not warranty due to abuse, ect. In your case your tires were junk to start with.
I would not want tires from the manufacture. I would get my own tires and keep the old ones for proof. Keep a detailed log of everything you do and receipts. Also, make sure they balance your new tires. Many believe trailer tires do not need to be balanced but it makes a big difference. I am guessing yours are not balanced currently.
Chris
/ Trailer Tire Question. #16
Once I bought a set of tires and they all went bad from Firestone... they were not expensive tires. They would split in the tread and develop lumps... well, two did and I wasn't going to wait for the other two.
I quickly replaced them with Michelins and no more problem...
Several years later I read there was a massive recall... all you had to do was bring in the tire for a full refund or exchange... you had to physically have the tire... which I no longer did...
/ Trailer Tire Question. #17
Sad but true. The last four years have not been fun for the trailer industry and many companies are 'shaving the edge' of things too much. With 3,500lb axles, i would say that it is very likely your right rear spindle has gotten 'tweaked'.
It happens a lot more often on the right side than the left, because people have a tendency to hop over curbs with trailers while turning right. Go find something extremely straight and lay it front to back across the faces of both wheels on that side. If the spindle has gotten a little bent, then the tire will not be straight with the front one.
The funny thing is that i usually have people bend the FRONT right side spindle. Doing on the rear is a little unusual, but well within the realm of possibility.
Hope this helps.... now, go spring for a new set of steel belted st205/75R-15 C rated trailer tires and you will be good to go.
Craig Hull
AKA the trailer guy
Stateline Trailers
/ Trailer Tire Question. #18
:mad:
Krewz
That is CRAZY! What kind of crap is that? Grinding off part of a tires name? Like... REALLY? Unheard of
/ Trailer Tire Question. #19
I'll bet if you read your 1 year warranty it excludes wheels, tires, flooring and paint. Because those all things that get horribly abused on trailers and no one warrants them. It still stinks, but Caveat here... you have to LOOK at what you are paying for BEFORE you buy it. Hope you can get past it.
The Trailer Guy
/ Trailer Tire Question. #20
The Trailer Guy
Even when I did a lot of auto arbitration cases... tires were always in a separate category and the manufacturer's written warranty most often referenced the separate tire manufacturer's warranty card.
2014 KENWORTH T370 QUINT/A  DUMP TRUCK (A59906)
2014 KENWORTH T370...
2019 John Deere 4044M (A62177)
2019 John Deere...
2005 Komatsu PC 200 LC (A60462)
2005 Komatsu PC...
2025 SDLanch SDLE20 Diesel Mini Excavator (A60352)
2025 SDLanch...
1988 Lufkin CM-320D-305-100 Road Runner Mobile T/A Oil Field Pumpjack (A60352)
1988 Lufkin...
SKID STEER ATTACHMENT PICKER (A58214)
SKID STEER...
