Trailer Suspension Problem
/ Trailer Suspension Problem #11
The center equalizer hanger looks too short to allow both shackles to be on top where they should be.
/ Trailer Suspension Problem #12
Where do you usually keep the springs? They should be hung on the topside of the equalizer.
Thats what i'm thinking too: To take care of all problems, the best option is to cut off this equaliser bracket and lengthen it something like 8 inches (double the length of the hanger) so the springs are allways lke Diamondpilots picture suggested, without the rear curl in the leaf, or the axle itself, touching the frame.
/ Trailer Suspension Problem #13
I think they should both be "OVER".
Someone might have been seeking extra height, perhaps when overloading it, and decided that "UNDER" would give the trailer more capacity.
Both "OVER" would seem to be the stable position that they are seeking.
Somewhere in the dusty recesses of my memory is a measurement of 26 1/2 inches as a standard, but that is not a very reliable area of memory.
This is how it ended up
Hope it stays this way.
/ Trailer Suspension Problem #16
I agree the spring perches need to be removed and move fwd/aft to lengthen the springs so the springs don't ride on the center pivot/rocker.
/ Trailer Suspension Problem #17
Yes, there is a problem! It may be advisable to consult a reputable trailer builder to get some proper advice.:D
/ Trailer Suspension Problem #18
There is something not quite right there but the eye of the spring doesn't look like it will hit the frame. Looks like it might it the rocker though.
I think the term is called shackle inversion and sometimes you need to weld little catch blocks to keep it from inverting. Happens more often with short shackles, soft springs, and arched springs. Normally when the wheel droops into a hole and the shackle over-centres.
/ Trailer Suspension Problem #19
Looks like when the trailer was made, end brackets were used instead of the longer equalizer barcket for the center position. Oops. Burn, weld. Parts at TSC. Done. As I now take my Alzheimers meds, I recall options for walking beams with taller sections. That might be an easier and more cost effective solution. I think I weld pretty good but don't trust my work enough to modify a trailer going down the road with a heavy load...
/ Trailer Suspension Problem #20
As a follow up, I checked my own trailers for this issue and see that my frame brackets are identical in height to those shown, but my walking beams are equilateral triangles and much larger than those shown. You do Not want a taller bracket because the side forces from the axle and springs will fatigue and eventually break taller brackets. TCS has several sizes of walking beams on their racks here in Michigan. That's your solution.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
Hyster H90XMS Forklift (A59213)
Hyster H90XMS...
2015 MACK CHU613 DAY CAB ROAD TRACTOR (A58375)
2015 MACK CHU613...
1995 John Deere 5300 (A60462)
1995 John Deere...
KJ K2223 23'x22' Metal Shed (A60463)
KJ K2223 23'x22'...
