Trailer moving ability??
/ Trailer moving ability?? #1
Anonymous Poster
Epic Contributor
As long as everyone's in the mood talking about wheel motor torque and I'm drawing close to setting a date for the pilgrimage (to Tazewell), I'm hoping others out here use their 400 series to jockey trailers around the yard(driveway)...
What are some of the heavier weighted trailers that have been moved about. I'm really hoping I can move a 5-6k(tongue less than #700) tandem axle trailer infrequently or is this just wishful thinking...
/ Trailer moving ability?? #2
Since I have an 1845, I can't be really sure, but my guess is you will have no problem moving your trailer around, and with good control, on the level. I move a dump trailer to get manure out of the barn and through a narrow road to a compost area. Riding forward and pushing the trailer backward is ridiculously easy, and you can back it into amazingly tight spaces. (You can create a challenging situation if you drop off in the garage and then rehook at an angle. Straightening out to pull it out may require rehooking.)
As to the weight, you'll probably have enough power to move the rig on the level with no problem. I'd be concerned on slopes, however, that you don't have enough weight to stop it if it starts downhill. Pulling, on most surfaces I'd bet you'd run out of traction before running out of power. Braking would be problematical if the PT starts to slide. It shouldn't be hard, however, to wire a plug to activate the trailer brakes with a pushbutton or better, a toggle switch. With the latter, if it started to get away, you could lock everything and chock it off while you figure out the right solution.
Thanks charlie,
As it turns out I do have a 2.75 deg slope on driveway...The trawler has surge brakes and the Jayco has electric...I do have plans to make (elec.) brake hookup and thought I might hang a 4x4 post from the rear of the surge braked tr. with enough slack to lay down and block the wheels if I stop for any reason and if the PT won't hold on cement drive. Most likely I'll have a spotter in either case...standing by with chocks...
Good safe thinking.../w3tcompact/icons/clever.gif
/ Trailer moving ability?? #4
Charlie: <font color=red>Riding forward and pushing the trailer backward is ridiculously easy, and you can back it into amazingly tight spaces</font color=red>
This may be a bit off topic, but pushing a trailer down the road at full tilt without jackknifing is enough to bunch the shorts. And since I need to move stuff up to a couple of miles, this just won't cut it. My thought of the day is to put a quick attach plate on a trailer with big caster wheels; then it would push like any attachment with casters. Then like the PT power dumper, just lift & curl to dump it.
/ Trailer moving ability?? #5
Sedgewood:
I certainly wasn't suggesting pushing a trailer at high speed down the road. That's what you have a Tacoma for -- or the 2" receiver I welded to the back of the 1845. With that, when I run down the road at the PT's full 11 mph, the trailer obediently follows. But for backing it at speeds where emergency reflexes need not be tested, precise placement is very easy.
Why you always gotta muddy da water?? /w3tcompact/icons/grin.gif
/ Trailer moving ability?? #6
Charlie: <font color=red>I certainly wasn't suggesting pushing a trailer at high speed down the road.</font color=red>
No. I was. As usual I wander off a bit. This all just reminded me of my long wait for the magic power dumper to appear - only to discover I hadn't thought my application through - its seldom I need to move stuff only a few feet. The power dumper is pretty close to what I need - except I need to travel farther with the stuff. Stuff like firewood, gravel, topsoil, tree debris. Go to the far side, get a load, bring it back and dump it. Repeat. At the extreme that can be close to a mile, some of it on public road - kinda like your situation. The grab & go of the quick attach is far more convienient than hitch & unhitch, especially if I have to drive the Tacoma & a trailer way over there (where it can't wiggle into anyway) and walk back for the PT. I wanna high speed power dumper.
<font color=red>But for backing it at speeds where emergency reflexes need not be tested, precise placement is very easy.</font color=red>
I've just got a bad case of bubenbergitis festering here; I want precise, I want quick switch, and I want fast too. Now ya take a bubenberg superboom with a nice quick attach coupler out at the end - snap on a power dumper out there and you can precisely place it in the next county!! Then with the minhoe ya can bury the wheellbarrow for good. Way over there cause ya snapped the minihoe on the superboom. Oh gawd I've gone too far now... must be that last canopy konk on the head */:) casters
<font color=red>Why you always gotta muddy da water?? </font color=red>
So I can't see my reflection?
/ Trailer moving ability?? #7
Stop it! /w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif/w3tcompact/icons/laugh.gif
/ Trailer moving ability?? #8
I have a 4' by 8' hay trailer that I fill with cord wood and haul with my PT425. I have little problems on flat ground but I must keep the equipment rolling to make it up hills.
/ Trailer moving ability?? #9
ptrich, long time no see you, happy new year.
based on your comment, i understand much better what you were saying when earlier we were talking about the power dumper.
PT,
Good to hear from you...how is that 425 holding up...hrs?
/ Trailer moving ability?? #11
I have used my pt 422 to move an international scout for a neighbor pulling with a chain hooked to the rear hitch of the pt for a short distance on almost level ground with no problem, and we also used the power trac to move a large gravity wagon full of ear corn probably about 4 tons total weight. The hitch on the wagon would not work on the rear pt hitch so i just went to the back of the wagon frame and pushed it with the bucket with no problem, again this was on pretty level ground and for just a short distance.
Ernemats,
Just the kind of experience I'm looking for...I remain optimistic on my (near) future 422...Thank You.
/ Trailer moving ability?? #13
did i tell you guys lately that i am still amazed what i can do with this little thing. today we dug a foundation for an addition to a house. the ground was frozen solid. so of we went and drilled down 36 inches, hole after hole. four feet wide and 60 feed of which twenty were at a right angle, so not just a simple push forward. 6 hours later we had loaded every thing (five tons at the time) by driving the dirt up the ramp of our dump trailer.
Could have never fit the Kubota L2050 back there.
What a Machine the PT 425 is.
/ Trailer moving ability?? #14
bubenberg: <font color=green>today we dug a foundation for an addition to a house.</font color=green>
Wow, I'm impressed! - How deep do you guys go down there - up here its 4 feet minimum to get a foundation below frostline.
/ Trailer moving ability?? #15
i guess, since i am only the digging sub that that is all that's required for this pole barn type addition. i know we only go this deep for decks around here and the inspectors are going on their belly's and reach down in the holes with a measuring stick.
Hans,
The PHD w/6"&12" auger is on my list already.../w3tcompact/icons/grin.gif
...but I'm still curious about the technique used to "trench" with a PHD...how close to the 1st hole do you start the 2nd and subsequent holes to achieve that "trench"...it would seem if it was too close, the auger would wander off center...or is the auger inserted and then "dragged" or "pushed" like a "ground router"...
/ Trailer moving ability?? #17
Bkmar: If it's any help, I've got a 2" ball on the back of my old PT1418, and I was able to tow a 5x8 trailer loaded down with a cubic yard of sand (about 2300 lbs), both up and down a small incline (around 12" slope every 10 feet).
HTH,
Dave
2014 KENWORTH T370 ROAD TRACTOR (A65054)
2014 KENWORTH T370...
1993 International 4900 Utility Flatbed Truck (A64194)
1993 International...
3PT 10' Rolling Cultivator (A60462)
3PT 10' Rolling...
2012 Great Dane 53' Van Trailer (A66285)
2012 Great Dane...
2009 CHEVROLET 3500HD 4x4 PICKUP TRUCK (A59912)
2009 CHEVROLET...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
