Trailer Modification
/ Trailer Modification #31
BobRip said:
Yes, another bucket or mower will fit under the top bucket. I was going to use the racheting straps to hold the bucket down. I use three on the tractor, I think one on the bucket should be enough. Do you agree?
Of course the brackets around the teeth will help in a panic stop. Also the guide pieces on the sides help.
Well, I wear a belt AND suspenders and am a big fan of the saying, "A pair and a spare!". :D
Let's think about it. As long as the bucket teeth are confirmed to be in the hold down brackets, the most likely place the bucket would fall if left unstrapped or if a strap broke or came loose would be backward, into the trailer. All of the weight of the bucket is supported well, so all a strap would have to do is keep it from bouncing around. If you get in a wreck going forward, the brackets should keep the bucket in place. It looks like you have some side braces on it, too. One sturdy strap should be fine. A second would just be peace of mind, I think.
Richardton 960 (A60462)
Richardton 960...
SEMI AUTOMATIC QUICK-CHANGER FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
UNUSED FUTURE 350 HYD BREAKER HAMMER (A52706)
UNUSED FUTURE 350...
UNKNOWN 500BBL WHEELED FRAC TANK (A58214)
UNKNOWN 500BBL...
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
2014 FORD F-250 XL SUPER DUTY EXT CAB TRUCK (A59823)
2014 FORD F-250 XL...
