Trailer for BX23
/ Trailer for BX23 #1
JeffJ
What length trailer do I need to transport a BX23 with the loader and Backhoe attached? What is the total length of the Tactor with Loader and Backhoe? I have a 6x12 landscape trailer now with 2 foot side mesh, dual axle (7000lbs). Just need to know if I need new tractor. Thanks for any help
Jeff
/ Trailer for BX23 #2
I was able to get mine on a 14' using a shoe horn, but 16' would be better. Dual wheels are also a plus, and brakes are a absolutely needed option. If you are going to be hauling it with the mower deck attached, take your measurements and check the width between the fenders.
/ Trailer for BX23 #3
That trailer will haul it, I hauled mine on a single axle trailer that was about 5 x 10 with the 54 inch deck, The loader bucket was hanging over the front of the trailer a bit but wasn't in the way of turning and I had the backhoe turned all the way to one side instead of straight out the back. I did have to bungee the mower chute in the up position because it stuck out too far. If you don't want anything hanging over the ends of the trailer (loader or backhoe) then you need something longer, but you shoud be ok width wise
/ Trailer for BX23 #4
Here is a pic of my BX2230 with FEL and Box Blade on my 18' car hauler. It shows plenty of room. I would tink a 16' would be fine and a 14' minimum. Make sure you have brakes on any trailer used to transport this much weight.
/ Trailer for BX23 #5
I have a 16 ft. tandem axle 7000lbs. trailer with the mesh sides. The trailer also has trailer brakes. I have room left over when I haul the tractor with loader and tiller or box blade on.
/ Trailer for BX23 #8
A 6x12 tandem axle will work, but it will be a tight fit. A 16' would be better. Try and see how you like the 12' trailer you have first.
Will
/ Trailer for BX23 #9
I haul a BX2200 with a box blade up front (FEL over it) and the tiller on the rear on a 5 x 14 trailer. Not been a problem for me.
Ron
/ Trailer for BX23 #10
I use a 14' dual wheel trailer with disk brakes to trailer my BX23 to my block each weekend. Approx 50 mile, half dirt road over the mountains.
Fits nice. /forums/images/graemlins/grin.gif
/ Trailer for BX23 #11
I have your exact tractor, I use a 16' flat bed with a 2' dove tail for a total of 18'. Fits great. Dual axles with brakes on at least one, mine has brakes on both. I would not pull it on less than this, nor would I pull it without brakes on the trailer.
/ Trailer for BX23 #12
What's the consensus on trailer brakes? A couple replies have been strongly advocating them. Obviously they're a good idea, but are they mandatory?
My dealer delivered my BX on a 12' trailer with the FEL hanging over the front and BH off to the side as described above. The guy said the trailer did not have brakes when I asked him about it, and he didn't seem like it was a big deal.
I don't expect to do much trailering, but I'd like to know what to look for in case an opportunity presents itself.
/ Trailer for BX23 #13
Brakes aren't important unless you care about stopping distances and safety. Most states now require brakes on all trailers at a certain weight point. I believe that NY is the lowest around 2000#. Homeowners insurance, nor your cars insurance will pay for damage to the tractor in the event of a accident while trailering it, so why take the chance???
/ Trailer for BX23 #14
Like Junkman said, most states have laws requiring trailer brakes on trailers over a certain weight. I think about 4,000 pounds, plus or minus some, is common. Over 30 years ago, the federal government was recommending states pass laws requiring trailer brakes on any trailer that weighed more than 40% of the weight of the vehicle pulling the trailer. I've pulled lots of different trailer and trailer weights, both with and without trailer brakes, and naturally, you can do without the brakes, but it sure is safer and more comfortable with them. /forums/images/graemlins/wink.gif
/ Trailer for BX23 #15
Junkman
I have USAA insurance and they cover the trailer and contents while towing. I have a 'problem' towing snowmobiles once and all was covered.
/ Trailer for BX23 #16
I've towed my BX22 on a 12' 5000 lb. trailer and while it did fit (barely), it just didn't "feel" right. That could be due to a number of things but I suspect it was because the weight wasn't distributed properly (not enough tongue weight?). At minimum, I would go with a 14' tandem axle with brakes, but a 16' would be better for proper weight distribution.
/ Trailer for BX23 #17
12 foot trailer is indeed tight and when I used one that I borrowed from a family member as said, it did not feel right. The guy that helped me load it, centered the weight over the axle and it towed terrible. I would much rather have about 60% or a little more of the weight toward the font of the trailer so you have more weight on the tongue, otherwise I have always felt the bounce and sway of the trailer anytime speeds get much over 40 MPH I think if the tractor had been a little more forward on the trailer it would have towed a lot better but on a 12 foot trailer there just wasn't any room to move it forward any further I would think a 14 or 16 for a BX23 would be great.
As far as brakes are concerned I would say it depends on what you are towing it with. My Dodge 1500 truck stopped fine without trailer breaks towing my BX as long as I left a little extra stopping distance. Trailer brakes are nice if you have to stop in a hard breaking situation though. When I get a trailer for my BX I am going to try my best to find a Dual axle, If it has brakes that is a bonus if it doesn't I would not hesitate to tow the BX without them.
/ Trailer for BX23 #19
I think in NY it is GVW of 3000 lbs or above (thus 2990 rated units without brakes) or trailer weight itself over 1,000 or 1,200 lbs (I can't remember exactly which one).
All I can say is if you plan to trailer more than a short distance or on a regular basis you should have breaks. You may not have an issue once, twice, twenty times, but if you ever have to stop, you will know that tractor is back there and without the brakes you definately won't stop as quickly.
Also to consider is that if the load is not correct, trailer brakes can save you from an uncotrolled sway.
I wrecked a trailer once which was fully loaded (probably somewhat overloaded) that didn't have brakes and got into a sway. It threw my Ford Expedition all over Interstate 95 and I was lucky not to hit anyone else or roll the thing.
I hope I never repeat that and hope nobody else does either.
Brakes are cheap insurance on both your goods and your life.
Remember it's not just how you drive you have to worry about it's everyone else too.......like that "person" that pulls out in front of you because there is a 30' gap between you and the car in front
/forums/images/graemlins/mad.gif
Just some things to think about.
/ Trailer for BX23 #20
My BX23 was delivered on a single axle 6x12 w/o brakes. The FEL was resting on the front trailer's railing whilst the BH was angled all the way to one side which allowed the lift gate to close completely. The fellow what delivered it said brakes would be nice but not necessary as long as one is careful!
I too have a 6x12 w/a single 3500lb axle and no brakes and I plan to use it should the need arrise to transport the BX23. The Kubota dealer is within 10 miles as is my other property so I won't hesitate to use my existing trailer.
I'd say if you're going to transport the BX alot with many additional implements (as in going to a job site, etc.) that a larger trailer would be necessary to carry it all easily.
As for brakes, I'm gonna assume that brakes aren't required for a 6x12 single axle in my state as I bought it from a licensed dealer but I do notice that all the double axle trailers I have seen do have them.
If I ever do upgrade to a larger twin axle trailer, it'll have brakes!
Volfandt
2014 Toro Workman MDE Electric Utility Cart (A61567)
2014 Toro Workman...
2006 Isuzu NPR-HD Crew Cab Landscape Dump Truck (A61568)
2006 Isuzu NPR-HD...
2014 CATERPILLAR 573C FELLER BUNCHER (A62129)
2014 CATERPILLAR...
1987 CATERPILLAR D6H HIGH TRACK CRAWLER DOZER (A52709)
1987 CATERPILLAR...
New/Unused Landhonor 72in Rock Grapple (A61166)
New/Unused...
1988 FRUEHAUF CRANE TRAILER (A60736)
1988 FRUEHAUF...
