Trailer came off ball?
/ Trailer came off ball? #21
I got your toys, 2006 F-350 PSD 4x4, 2004 F-250 PSD 4x4, 1999 F-350 PSD 4x4, and the grocery getter 2007 F-150 4x4. We tow loads every spring and fall with Pintle hitches upto 80,000# using everything from the F-350's to Dump trucks and even Peter Builts. You are a either blind or dumb if you think there is no wear to the drive line of anything if you are towing with a Pintle hitch. There is slop that is not there with a ball hitch or 5th wheel.
Like I said before the Pintle setup has its place but it is what it is.
Chris
/ Trailer came off ball? #22
Have I got it right that you should load your trailer for 10% tongue weight?
That would make my trailer with tractor weight of 8800# give a tongue weight of 880#.
/ Trailer came off ball? #23
"I have never seen a coupler, that you cant adjust."
I have a couple bulldog type that have no adjustment. probably don't need one due to the design.
Couplers have been known to wear out so badly that a ball is not properly secured. Negative tongue weight would certainly be one way of finding that problem. I have never heard or seen a recommendation from any authority to use less than 10% tongue weight.
Pat
/ Trailer came off ball? #24
Chris
Ford = Toy.....:rolleyes: So I am sure you are having drive train trouble
/ Trailer came off ball? #25
I had our 4 ton equipment trailer come unhooked going up a hill empty, I had already towed the trailer 20 miles. I believe I didnt make sure the coupler was locked down properly. Now every time I hook the trailer up before I crank up the jack I start cranking it down and make sure the coupler is properly latched. V
/ Trailer came off ball? #26
Big Horn, Begin reading about "Dodge". Probably won't be around in a few years.
/ Trailer came off ball? #27
Harry, 10-15% is often the recommended tongue weight.
Some references say 5-15%,
I have never seen less than 5% recommended by a credible source.
If your hitch or truck can't handle the tongue weight at 5-15% then maybe you are overloaded and or need weight distributing hitch.
Pat
/ Trailer came off ball? #28
Dodge = Made in Mexico.... But not for long, all the workers are all moving across the border.
2019 BOBCAT T740 SKID STEER (A62129)
2019 BOBCAT T740...
HYDRAULIC THUMB FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2015 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A60352)
2015 Peterbilt 567...
PJ  32 FLATBED GOOSENECK (A58214)
PJ 32 FLATBED...
2019 Chevrolet Express Box Van, VIN # 1HA3GTCG9KN007839 (A61165)
2019 Chevrolet...
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
