trailer brakes
/ trailer brakes #31
Thanks Bird,
Maybe my vendor was over that limit carrying all those truck tires, or plated higher anyway.
/ trailer brakes #32
The surge brakes issue is something that is still getting kicked around by the D.O.T. and other lawers and industries (rental) that have a vested intrest.
The great state of Indiana and a few others seam to have a real tough time getting along with other states and their regulations that pertain to trucking. That includes but is not limited to surge breaks.
I PERSONALLY require breaks (that really work) on ALL axels, period, END OF DISCUSSION.
As far as the lawer crack about how good is he...
Just try rearending someone who has a GOOD lawer, and you dont have enough breaks, overloaded, insecure load, not enough of the right kind of insurance, on and on, and on...It could get real nasty and expensive. It is a cold hard fact of insurance... it is cheaper to kill someone on accident, than it is to hurt someone on accident. Breaks are much cheaper.
I like more WOA than GO !!
Have a good day. virgil
/ trailer brakes #33
<font color="blue"> I tried to distribute the weight as best I could, but had to have a 5-6' tiller up against the front of the trailer and drop the FEL bucket on it. I not sure if that could account for the wheelie I was doing, but I'm sure it didn't help. Any other tips on distributing the weight on a car hauler? </font>
Woodlot
I took a couple of pictures this morning when I picked up my JD Front Mower. It weighs about 1500 pounds. Put it all the way forward on the trailer.
First picture is with mower off trailer.
/ trailer brakes #35
Looks a little too far forward to me. I'd load so that the CG of the mower is about even with the front trailer axle. That should put a reasonable amount of weight on the hitch.
/ trailer brakes #36
I have noticed that my brake controller on the sport trac is now showing 0.0 when I dont have the trailer on and brakes are applied. It is supposed to be just a dot. I just had a brake job done on the trac, wonder if they screwed up something. It is a Reese controller and the trailer company that installed it had to run all the cabling.
Any ideas?
/ trailer brakes #37
I thought DOT was mandating brakes for anything over 5k in many states? ( and break-away safety devices ).
As for tounge weight.. i like to keep the bulk of the weight near the center of the to rear axles.. then gauge tounge weight on the truck for fine tuning.
Soundguy
/ trailer brakes #38
</font><font color="blue" class="small">( my brake controller on the sport trac is now showing 0.0 when I dont have the trailer on and brakes are applied. It is supposed to be just a dot. )</font>
My controller from drawtite also shows a dot when disconnected but breaks on.. , and then the x.x when the trailer's connected depending on breaking force.. etc.
Soundguy
/ trailer brakes
I got my new brake controller yesterday, works great. I was getting strange LED lights on the old one, especially when the trailer was NOT connected. I called tech support and he had me explain the light pattern. Right away he said it was defective and had a new one in the mail the same day. My advice, if you think something might be haywire call tech support. Oh, the trailer breaks where not working too, that was another tell-tale sign.
CASE ROOT PLOW (A58214)
CASE ROOT PLOW...
2018 Ford Explorer AWD SUV (A59231)
2018 Ford Explorer...
2020 PETERBILT PB337 SERVICE TRUCK (A59823)
2020 PETERBILT...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
2017 Ford Explorer AWD SUV (A59231)
2017 Ford Explorer...
2015 Ford Explorer AWD SUV (A59231)
2015 Ford Explorer...
