Trading in M7040 for M7060
   / Trading in M7040 for M7060 #21
Creep is a third position on the hi/low range leveler, very easy to use. I have a 72" Bushhog root-tiller that is a older heavy duty unit. My ground in heavy compacted clay that first pulled a chisel plow across then tilled. Lots of rock, broken bricks, and shale hunks scattered about. Traveling really slow let me raise the tiller when striking a object.
Well luckily we don't have rocks in the soil in the deep south where I live, thank goodness!
   / Trading in M7040 for M7060 #22
I have considered adding creep to my tractor for snow blowing, you know that white stuff you see on the news sometimes? :D
It is a dealer installed option.
Creep would work great for blowing heavy snow. I use. 25 hp grasshopper mower with 60" blower.
It will handle 8-12" no issues as long a stake it slow.
Would be really fun to mount a 84" rear mount blower on the tractor.
   / Trading in M7040 for M7060 #24
I have a new M7060 due to be delivered this week. I upgraded to radial tires which will get the wider front tires. They do not show as an option in the USA but my dealer was able to get them.
Mine should look like this:
Do you have anymore information about those front tires?
   / Trading in M7040 for M7060 #25
   / Trading in M7040 for M7060 #26
Someone in the owning/operating forum posted a how-to install on this kit. As I recall, it requires draining all the hydro fluid, which is substantial on this tractor. Other than that, it read like it was a piece of cake.
HP
   / Trading in M7040 for M7060 #27
HP
Since my dealer has mine this week to install the 3rd function kit that arrived late, I just had them go ahead and order the kit and install it there. Was $850 or so installed. I think it will be a nice addition for several of my uses.
   / Trading in M7040 for M7060 #28
Please reply with your thoughts on the creeper kit
   / Trading in M7040 for M7060 #29
probably stating the obvious... unless the creeper gear design has changed, kubota clearly states that the creeper use is designed for light use (drilling, spreading, etc) and not for use as heavy soil engagement or fel use that builds up gear stress. so i'd be leery of heavy plowing or fel excavation using the creeper gears. please correct me if this is not so.... just a precaution
   / Trading in M7040 for M7060 #30
I have no plans of doing anything stressful in creep speed, mainly just for mowing road and trail sides with my Lane Shark, since 1L is too fast for really thick areas. The Kubota disclaimer in the OM has been hashed over a good bit also and I have yet to find one instance of "improper use" breaking anything.
2018 Bobcat T590 (A50120)
2018 Bobcat T590...
Cat TH407C Telehandler (A52748)
Cat TH407C...
2006 John Deere HPX Gator 4x4 Utility Cart (A50322)
2006 John Deere...
KJ 33'x25' Double Garage Steel Barn Shed (A50121)
KJ 33'x25' Double...
2025 12V Diesel Pump, Hose And Nozzle (A50323)
2025 12V Diesel...
2011 DODGE RAM 2500 (A52472)
2011 DODGE RAM...
