Trading in M7040 for M7060
   / Trading in M7040 for M7060 #21
Creep is a third position on the hi/low range leveler, very easy to use. I have a 72" Bushhog root-tiller that is a older heavy duty unit. My ground in heavy compacted clay that first pulled a chisel plow across then tilled. Lots of rock, broken bricks, and shale hunks scattered about. Traveling really slow let me raise the tiller when striking a object.
Well luckily we don't have rocks in the soil in the deep south where I live, thank goodness!
   / Trading in M7040 for M7060 #22
I have considered adding creep to my tractor for snow blowing, you know that white stuff you see on the news sometimes? :D
It is a dealer installed option.
Creep would work great for blowing heavy snow. I use. 25 hp grasshopper mower with 60" blower.
It will handle 8-12" no issues as long a stake it slow.
Would be really fun to mount a 84" rear mount blower on the tractor.
   / Trading in M7040 for M7060 #24
I have a new M7060 due to be delivered this week. I upgraded to radial tires which will get the wider front tires. They do not show as an option in the USA but my dealer was able to get them.
Mine should look like this:
Do you have anymore information about those front tires?
   / Trading in M7040 for M7060 #25
   / Trading in M7040 for M7060 #26
Someone in the owning/operating forum posted a how-to install on this kit. As I recall, it requires draining all the hydro fluid, which is substantial on this tractor. Other than that, it read like it was a piece of cake.
HP
   / Trading in M7040 for M7060 #27
HP
Since my dealer has mine this week to install the 3rd function kit that arrived late, I just had them go ahead and order the kit and install it there. Was $850 or so installed. I think it will be a nice addition for several of my uses.
   / Trading in M7040 for M7060 #28
Please reply with your thoughts on the creeper kit
   / Trading in M7040 for M7060 #29
probably stating the obvious... unless the creeper gear design has changed, kubota clearly states that the creeper use is designed for light use (drilling, spreading, etc) and not for use as heavy soil engagement or fel use that builds up gear stress. so i'd be leery of heavy plowing or fel excavation using the creeper gears. please correct me if this is not so.... just a precaution
   / Trading in M7040 for M7060 #30
I have no plans of doing anything stressful in creep speed, mainly just for mowing road and trail sides with my Lane Shark, since 1L is too fast for really thick areas. The Kubota disclaimer in the OM has been hashed over a good bit also and I have yet to find one instance of "improper use" breaking anything.
Kubota KX080-3 Midi Excavator (A50322)
Kubota KX080-3...
2013 Jeep Patriot SUV (A50324)
2013 Jeep Patriot...
1985 Toyota Pick Up Truck (A50515)
1985 Toyota Pick...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A50323)
2009 Peterbilt 384...
2007 STERLING T/A DAY CAB ROAD TRACTOR (A51243)
2007 STERLING T/A...
2020 Chevrolet Tahoe SUV (A50324)
2020 Chevrolet...
