Trading in M7040 for M7060
/ Trading in M7040 for M7060 #21
Creep is a third position on the hi/low range leveler, very easy to use. I have a 72" Bushhog root-tiller that is a older heavy duty unit. My ground in heavy compacted clay that first pulled a chisel plow across then tilled. Lots of rock, broken bricks, and shale hunks scattered about. Traveling really slow let me raise the tiller when striking a object.
Well luckily we don't have rocks in the soil in the deep south where I live, thank goodness!
/ Trading in M7040 for M7060 #22
I have considered adding creep to my tractor for snow blowing, you know that white stuff you see on the news sometimes? :D
It is a dealer installed option.
Creep would work great for blowing heavy snow. I use. 25 hp grasshopper mower with 60" blower.
It will handle 8-12" no issues as long a stake it slow.
Would be really fun to mount a 84" rear mount blower on the tractor.
/ Trading in M7040 for M7060 #25
/ Trading in M7040 for M7060 #26
Someone in the owning/operating forum posted a how-to install on this kit. As I recall, it requires draining all the hydro fluid, which is substantial on this tractor. Other than that, it read like it was a piece of cake.
HP
/ Trading in M7040 for M7060 #27
HP
Since my dealer has mine this week to install the 3rd function kit that arrived late, I just had them go ahead and order the kit and install it there. Was $850 or so installed. I think it will be a nice addition for several of my uses.
/ Trading in M7040 for M7060 #28
Please reply with your thoughts on the creeper kit
/ Trading in M7040 for M7060 #29
probably stating the obvious... unless the creeper gear design has changed, kubota clearly states that the creeper use is designed for light use (drilling, spreading, etc) and not for use as heavy soil engagement or fel use that builds up gear stress. so i'd be leery of heavy plowing or fel excavation using the creeper gears. please correct me if this is not so.... just a precaution
/ Trading in M7040 for M7060 #30
I have no plans of doing anything stressful in creep speed, mainly just for mowing road and trail sides with my Lane Shark, since 1L is too fast for really thick areas. The Kubota disclaimer in the OM has been hashed over a good bit also and I have yet to find one instance of "improper use" breaking anything.
/ Trading in M7040 for M7060 #31
sounds reasonable. just fyi for those who want to jump into slower ratios thinking they can expand that application other than your stated use. having the heavy duty 6 speed is a real bonus, smart move on your part
/ Trading in M7040 for M7060 #32
THREE POINT ATTACHMENT (A58214)
THREE POINT...
1986 New Holland L785 Compact Wheel Skid Steer (A59228)
1986 New Holland...
UNUSED FUTURE FT90 PLATE COMPACTOR (A52706)
UNUSED FUTURE FT90...
2024 HURRICANE GF480 - 48" ROTARY DRUM SCREEN (A52706)
2024 HURRICANE...
2018 Chevy Traverse 3rd Row Seating (A61306)
2018 Chevy...
HYDRAULIC TILTING BUCKET FOR MINI EXCAVATOR (A58214)
HYDRAULIC TILTING...
