TRADED 4510 for 4610
/ TRADED 4510 for 4610 #1
nightrodjc
04 Deere 4610 E-hydro
Sold my 03 4510 with power reverser and 460 loader to buy a 04 4610 with e-hydo and 460 loader. Hope I didn't make a mistake going to a hydro.
/ TRADED 4510 for 4610 #2
I don't think you will regret the hydro one bit!
What gear range do you hyro guys use to dig with ? Mine has A, B & C with A being low. Is it safe to use b range for loader work, if so then I wont have to shift at all:D . Just looking for a little input, I've only ever ran the gear models. Jim
/ TRADED 4510 for 4610 #5
I really depends on how nasty it is. I use B range for almost everything. For nasty stuff - A. C for transport. The e-hydro will tell you when it needs a lower gear - it just wont do it. 4wd and A range is pretty crazy my 4720.
Do you have a toothbar on the bucket? It is night and day difference digging.
Let us know what you think of the hyrdo after you use it a while.
D.
I was able to get a little seat time today on the hydro. The sounds it makes while digging seems odd to me, i'll have to get used to it. I used A & B ranges and it had no problem at all, I bet it turned an hour of diggin into a half hour and that was my first time digging with it. Thanks for the input, Jim
/ TRADED 4510 for 4610 #7
Do you think the reduction in time was due to the larger tractor or the e-hyrdo?
D.
D.
The 4510 and 4610 are the same tractor, they just added fuel to get 4 more h.p. it has same size engine. They both have the 460 loader and 4x4. I dig gravel out of the creek so it's alot of back and forth and turning around in tight spaces. I ran about 1600 rpm and B range so didn't need to shift at all and the hydro was just plain faster at this type of work. I started with a JD 750 gear then a 870 gear then the 4510 gear with reverser and now the 4610hydro all doing the same work and same location. Now the 4510 was a lot faster then say the 750 but their is a big diff. in size. Jim
New/Unused CFG Industrial MH12RX Mini Excavator (A65583)
New/Unused CFG...
2024 Bobcat T86 (A60462)
2024 Bobcat T86...
72" JCT TILLER (A62613)
72" JCT TILLER...
2002 Kenworth T300 TMA Attenuator Truck (A64194)
2002 Kenworth T300...
2010 GREAT DANE SUP-1114-31053 T/A REFRIGERATED TRAILER (A59914)
2010 GREAT DANE...
40ft High Cube Shipping Container (A65583)
40ft High Cube...
