Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #9,161
One of my saws is a Husqvarna 357XP, which is similar in power/performance to your MS360. It wears a 16" bar 95% of the time. I'd rather have the better balance, lighter weight and maneuverability of a 16" bar on this saw when working in the woods felling and limbing trees, and I find it a good match power-wise for that bar. (Of course, my 50cc saw also wears a 16" bar all the time.) Unless I know I'm going to spend a significant chunk of my day felling trees larger than 16", it wears the 16" bar, and I fell those occasional trees of larger diameter by cutting from both sides. It's extremely rare in this part of the Northeast that I would be felling a tree larger than I could drop with a 16" bar.
If I know I'm going to be working in bigger trees a lot that day, or if I'll be bucking up a lot of 16-20" firewood, I'll put on the 20" bar. While the specs say it can handle a 24" bar, I would not even consider putting something that size on it. If I needed 24" of bar for a significant amount of cutting, I'd switch to a bigger saw - probably a 70cc.
All of my cutting is in hardwoods (Oak, Maple, Beech, occasionally Ash or Hickory). If I were cutting large softwoods with any frequency, I might step up the bar size I'd put on a given saw a bit.
I’ve got a 28” bar for my 372xp but I hardly ever use it. The 20” is much better. Even when cutting bigger stuff I don’t usually switch them.
   / Tractors and wood! Show your pics #9,162
When your son gets ready to service the other three wheels there isn't a need to pull the tires off anyway. Remove the axle and lock nuts, then use a pallet jack to remove the tires, wheels and hub in one piece. Saves a lot of time.
Yup. And if you don't have a pallet jack, a couple of kids "crazy carpet" sliders with a bit of oil between them - anything to slide the complete hub/wheels/tires assembly off the spindle.
   / Tractors and wood! Show your pics #9,163
You missed my point, which was this: The 362 has 27% more power than the Husky. The 362 cuts slow with a 24" bar. Therefore the Husky would be really slow.
Yes, you are correct. I misread your point. Sorry about that.
   / Tractors and wood! Show your pics #9,164
Did you ever try skip chain on that longer bar ??
gg
   / Tractors and wood! Show your pics #9,165
gg
That would certainly be the way to go if he's burying a good bit of that longer bar in the wood.
   / Tractors and wood! Show your pics #9,166
On my 70 cc saw with a 25” bar a skip is often the chain I put on. Depends on the wood. With the 32” bar I would not even think of making up anything but a skip.
   / Tractors and wood! Show your pics #9,167
gg
It pulls the bar pretty good. I just don’t like carrying it around. I don’t like it sticking way out of a smaller log either.
   / Tractors and wood! Show your pics #9,168
Someone suggested I look at another Echo because I already have one. Well all my current power equipment is Echo. Chainsaw, weed eater and backpack blower. I think they build good equipment. So I went looking at them for a big saw. The cs590 Timberwolf comps to the 460 Rancher. But my question is HP, or how do you compare saws when you don’t have the hp rating? Then I found their cs680. It’s $100 higher than the husky, but it’s a 65cc saw. Still no hp rating. But a 20-28” bar range. It’s heavier than the 460. So does anybody have one or have you any opinions about them. If it’s a good saw I’d step up that $100 to the 65cc saw. Would this make a felling saw?
Local dealer I bought my other items from closed a few years ago. I’ve been buying the oil and filters I need from rural king. But I wouldn’t call them a dealer. Just a seller. I’ll have to look for dealers.
2004 Ford Taurus SE Sedan (A51694)
2004 Ford Taurus...
2016 Ford Focus SE Sedan (A51694)
2016 Ford Focus SE...
2015 JCB 525-60T4 5,500lb 4x4 Rough Terrain Telehandler (A51691)
2015 JCB 525-60T4...
New Long Forks (A53002)
New Long Forks...
2020 RoGator RG1300 Air Max Precision R2 Spreader (A53342)
2020 RoGator...
