Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #9,161
One of my saws is a Husqvarna 357XP, which is similar in power/performance to your MS360. It wears a 16" bar 95% of the time. I'd rather have the better balance, lighter weight and maneuverability of a 16" bar on this saw when working in the woods felling and limbing trees, and I find it a good match power-wise for that bar. (Of course, my 50cc saw also wears a 16" bar all the time.) Unless I know I'm going to spend a significant chunk of my day felling trees larger than 16", it wears the 16" bar, and I fell those occasional trees of larger diameter by cutting from both sides. It's extremely rare in this part of the Northeast that I would be felling a tree larger than I could drop with a 16" bar.
If I know I'm going to be working in bigger trees a lot that day, or if I'll be bucking up a lot of 16-20" firewood, I'll put on the 20" bar. While the specs say it can handle a 24" bar, I would not even consider putting something that size on it. If I needed 24" of bar for a significant amount of cutting, I'd switch to a bigger saw - probably a 70cc.
All of my cutting is in hardwoods (Oak, Maple, Beech, occasionally Ash or Hickory). If I were cutting large softwoods with any frequency, I might step up the bar size I'd put on a given saw a bit.
I’ve got a 28” bar for my 372xp but I hardly ever use it. The 20” is much better. Even when cutting bigger stuff I don’t usually switch them.
   / Tractors and wood! Show your pics #9,162
When your son gets ready to service the other three wheels there isn't a need to pull the tires off anyway. Remove the axle and lock nuts, then use a pallet jack to remove the tires, wheels and hub in one piece. Saves a lot of time.
Yup. And if you don't have a pallet jack, a couple of kids "crazy carpet" sliders with a bit of oil between them - anything to slide the complete hub/wheels/tires assembly off the spindle.
   / Tractors and wood! Show your pics #9,163
You missed my point, which was this: The 362 has 27% more power than the Husky. The 362 cuts slow with a 24" bar. Therefore the Husky would be really slow.
Yes, you are correct. I misread your point. Sorry about that.
   / Tractors and wood! Show your pics #9,164
Did you ever try skip chain on that longer bar ??
gg
   / Tractors and wood! Show your pics #9,165
gg
That would certainly be the way to go if he's burying a good bit of that longer bar in the wood.
   / Tractors and wood! Show your pics #9,166
On my 70 cc saw with a 25” bar a skip is often the chain I put on. Depends on the wood. With the 32” bar I would not even think of making up anything but a skip.
   / Tractors and wood! Show your pics #9,167
gg
It pulls the bar pretty good. I just don’t like carrying it around. I don’t like it sticking way out of a smaller log either.
   / Tractors and wood! Show your pics #9,168
Someone suggested I look at another Echo because I already have one. Well all my current power equipment is Echo. Chainsaw, weed eater and backpack blower. I think they build good equipment. So I went looking at them for a big saw. The cs590 Timberwolf comps to the 460 Rancher. But my question is HP, or how do you compare saws when you don’t have the hp rating? Then I found their cs680. It’s $100 higher than the husky, but it’s a 65cc saw. Still no hp rating. But a 20-28” bar range. It’s heavier than the 460. So does anybody have one or have you any opinions about them. If it’s a good saw I’d step up that $100 to the 65cc saw. Would this make a felling saw?
Local dealer I bought my other items from closed a few years ago. I’ve been buying the oil and filters I need from rural king. But I wouldn’t call them a dealer. Just a seller. I’ll have to look for dealers.
2007 GENIE S-60 4X4 MANLIFT (A50854)
2007 GENIE S-60...
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
2004 Big Tex 10PI 18ft T/A Pipe Top Utility Trailer (A49461)
2004 Big Tex 10PI...
STORAGE FEES (A51222)
2014 VOLVO VNM DAY CAB (A51222)
2014 VOLVO VNM DAY...
2010 International 4300 2,000 Gallon Water Truck (A49461)
2010 International...
