Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #24,701
Another day, another cart of wood to roll in and park beside the stove.
We have enough snow now,
gg
   / Tractors and wood! Show your pics #24,702
That said, if I were going to run a splitter off my tractor, it'd be closed-loop with a PTO pump. Way faster, as most CUT's can deliver much more HP thru the PTO than thru auxiliary hydraulics. Also keeps the systems segregated and clean.
In addition to GPM, another reason to use a PTO powered pump is the pressure. A compact tractor remote usually generates less than 2000 PSI. Considerably less than a PTO pump or a splitter with it's own engine.
   / Tractors and wood! Show your pics #24,703
Looks like the snow has gotten deep for you Mr. Gordon.
Does that put a damper on your logging?
   / Tractors and wood! Show your pics #24,704
Sent from my KFTRPWI using TractorByNet mobile app
Yes sir. Even if the tractor can I can't :rolleyes:
Nice day today and I find myself painting radiator covers that we don't even use ??? But they are rusty and have been on the to-do list about 4 years. Been a while since we've had a normal amount of snow like this.
gg
   / Tractors and wood! Show your pics #24,705
Interesting how there's always something needing done...
I generally stay active every day, but there are some tasks which finding the motivation to just go and do can be the toughest part of the job!
I too have a bit of minor interior touch up painting to do...it's been on the ToDo list for over a year. It's a winter time job...so maybe next winter!
   / Tractors and wood! Show your pics #24,706
   / Tractors and wood! Show your pics #24,708
Yep, and my to-do-list has a new entry. Build a 4 cord firewood shed (much) closer to the back porch! I'll still fill the 12' x 12' shed over 100' away, but I hate the thought of shoveling.
That’s a 16x6 shed with your wood stacked 5’. 5” high. If
you have the room, build two so you always have seasoning going on.
   / Tractors and wood! Show your pics #24,710
No... build six! I have four, all 16 x 6 x 8 high, and a fifth up by my barn... but it's not enough.
   / Tractors and wood! Show your pics #24,711
I worked at my desk all weekend, while it poured rain, so I could spend a little time out on the frozen turf splitting wood today. Thinking of this thread, I grabbed some pics in process.
Here’s an interesting aside: what saw gear and tools do you carry with you, when out in the field? I just cleaned out and reorganized my own toolbox, mostly eliminating duplicates and throwing away expired granola bars and jerky.
   / Tractors and wood! Show your pics #24,712
When tree stem gathering-One saw w 18” bar. 5 falling wedges of different lengths. A log peavy. 2 chains with sprocket tool and a 26” Hudson bay axe.
That’s it for tools.
Btw; if your saw is at the proposed cut in one of those pics, that's exactly how you handle a fork cut. Cut off the fork at the desired length, stand it upside down resting against the stem and noodle it apart.
When l was logging, we would just cut the fork out and leave it there.
   / Tractors and wood! Show your pics #24,715
We've had some discussions of Self-releasing snatch blocks in this thread. I find them one of the handiest accessories to have with my logging winch. They tend to be expensive (in the $300 to $400 range). I just stumbled across one of the better deals I've seen on one in quite some time.
Woodland Mills is selling them at $199. There is not a lot of info on their specs, so I emailed to ask. It is rated at 6 tons.
I have not seen this product in person, so can't comment on the quality. I'm not currently in the market for one, since I already own two different ones. I'd be curious to hear a review if anyone tries one of these out.
   / Tractors and wood! Show your pics #24,716
I wish the ground was still frozen here. Where I stack my split wood I have to cross about a 100 feet of my yard and it’s really soft now.
   / Tractors and wood! Show your pics #24,717
Good price comparatively. But I have no idea of quality. Looks kind of light but probably hard to tell. I have an Igland which is great but heavy. Wish it didn't weigh so much. That one sided bearing / spindle takes a lot of stress.
I will say Woodland Mills makes good stuff imo. I have a WM chipper with 200 hrs and no issues.
   / Tractors and wood! Show your pics #24,718
Same. For this reason, I always move 1 full cord up to high ground near my barn at the beginning of the season, while the ground is still dry from summer. That way, if I need to fetch more wood up to the house while the ground is soggy, I don't need to haul my wagon thru the low ground to my main wood staging area.
It's always a game in March or April, to make sure I use up everything stacked up at the barn, so the rack can be empty for summer. I don't like leaving firewood stacked near a structure in summer (bugs), and hauling that wood back down to the racks in the wood lot would screw up my FIFO stock rotation system. So, if I haven't already used it by late-March, I start grabbing from the rack at the barn, just be sure I get it gone and burned during April/May.
   / Tractors and wood! Show your pics #24,719
A poorly timed tractor breakdown caused me to miss the extended “frozen ground” window to drag up some firewood logs this winter. I had my splitter shed all cleared and ready go, but I had to push my Farnall Cub in there, when it quit running mid-winter.
Fortunately, the snowplow was raised when it quit and I was able to open the big swinging doors and push it in there with my John Deere loader tractor.
There will be no trouble hauling firewood up to the house during mud season though. I’ve got a high dry, 10 ft wide gravel driveway all the way around my woodshed and concrete up to the house.
Its been a good winter for burning wood. I’ve gone thru 5-1/2 face cords so far and my average the last (10) winters has been 6. I’m guessing I’ll get up to around 7 this winter.
It was too hot outside to run my woodstove last night, but it’s cooling down again now. 35 degrees at sunup is the upper limit for being able to maintain reasonably cool temperatures in the house with the woodstove operating. The colder the winter, the less natural gas I use because more of my heat comes from wood.
   / Tractors and wood! Show your pics #24,720
Nice setup, there!
I average 10 full cords per winter, but our house is large, old, and mostly uninulated stone construction. We have 60 windows, more than half of which were installed in 1775. We have 14 exterior doors, some of them dating back as far as 1734. This place ain't exactly the picture of optimum efficiency. :D
The last two winters, we got off easy, just 6-7 full cords. I was actually beginning to tell myself we were more efficient than we had been in the past, but the reality is that we just experienced two very short and very warm winters. This year having been more typical, until this week's warm spell, we're ripping thru a good bit more wood.
(1) 300 GALLON POLY TOTE W/CAGE (A60432)
(1) 300 GALLON...
Deere 410L (A53317)
Deere 410L (A53317)
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
2021 CATERPILLAR 926M WHEEL LOADER (A60429)
2021 CATERPILLAR...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
1999 John Deere 7810 (A60462)
1999 John Deere...
