Buying Advice tractor
/ tractor #1
ed8274
Plymouth Ma
none
Looking for advise on a tractor. Want to remove oak stumps 6"-8", some grading, dig for addition foundation apx. 15'X24', possible snow removal of drive apx. 550' long,. Have a 4+ acre lot with some steep area, but mostly not too much grade drop.
thanks for advice in advance
/ tractor #2
Welcome.
How many oak stumps do you plan on digging out?
Will you do any garden roto-tilling with the tractor?
The 550' driveway may turn out to be one of your main uses, so a definite on that would help.
Will you mow with the tractor?
If you want to dig stumps and a frost-wall? foundation yourself, you will need a backhoe attachment. If you can't foresee a use for it after that, it would be expensive to own just for those things. It would be cheaper in the long run to hire-out the foundation and stump work.
If you decide you need a backhoe, the Kubota TLB (tractor-loader-backhoe) units are hard to beat.
If you decide against a backhoe, I would get a small tractor with cab and front-mounted snow blower for the driveway. That and front-end loader for grading and general purpose, and maybe a 5' finish mower if you want a large lawn area.
/ tractor #3
my advise? hire out the stump removal.. then size/equip the tractor for the rest of the work that is 80% re-occuring.
don't buy a tractor with 1-time jobs in mind. buy it for the full time jobs...
/ tractor
Hi
thanks for the input
I have hunderds of future stumps to remove, lots of grade work, installing an above ground pool, and digging foundation apx. 15'X30', clearing and sanding 550' drive , want to have a large garden in the future, hopefully not a lot of grass to mow. Any input on the NorTrac tractors?
Ed
2007 Ford F-750 Water Truck w 2,000 Gallon Tank (A63689)
2007 Ford F-750...
2001 International 4000 DT 466E (A60462)
2001 International...
2008 Ford Mustang Convertible Coupe (A61574)
2008 Ford Mustang...
1986 Ford LN8000 Fertilizer Truck, CAT 3406 Engine, Ag-Ready Workhorse (A63689)
1986 Ford LN8000...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
Preliminary Listing / Full Catalog Coming Soon! (A62177)
Preliminary...
