Snow Tractor won’t start tonight.
   / Tractor won’t start tonight. #21
I have not; but they appear clean with zero corrosion and I’ve got 12.9v at the battery and just under that at the Hot connection on the starter.
Mahindra has had a common problem for battery, and battery cable connections needing cleaning and reconnected.
Also, have noticed the neutral safety switch on the HST has caused some starting problems.
Make sure the hydrostat pedal can freely return to the zero point (neutral).
As a battery gets colder it's internal resistance goes up and the voltage can change quickly. Battery may reach regulated voltage, but may not have recieved the current needed to properly charge the battery. This is more common as a battery ages.
After 2 hours of snow plowing you wouild think that the battery would be charged up. But at 6 years of age (if it has never been changed) I would look at replacing the battery. And cleaning the cable connection points.
MY opinion your mileage may very.
   / Tractor won’t start tonight. #22
Different kind of tractor, but I recently had a similar problem. The neutral switch was not bad, but it needed to be adjusted. The only thing I can figure is that the vibration of the tractor cause the switch to turn where it is mounted. In my case putting just a little pressure on the gear selector, not putting it completely in gear, allowed the tractor to start, just enough to cause the switch to be in the right position.
Thank you everyone for trying to help me. I’m up and having coffee now, then gonna go see what’s up. This is how I usually start my tractor. And I usually am standing outside the cab on the right hand side. I can easily reach the ignition from here.
1. Turn key backward to activate glow plug. Dash illuminates the symbol of the glow plug. I hold the key in this position for about 30 seconds.
2. Turn the key the other direction to Accessory and wait for all the dash lights, gauge’s, radio, etc. to cycle on and settle.
3. I push the brake pedal by hand and turn the ignition to Start. It usually fires right up.
Anyway, I’ll remove the dash cowling and try to find the Brake Safety switch. I’ll also check to see if the Brake lights are on EVEN WHEN the pedal is NOT being pressed with the key in the ON position.
   / Tractor won’t start tonight. #24
If you normally depress the brake pedal to start the tractor we can probably rule out stuck brake switch as cause of no crank. There is something else telling the tractor not to crank. That info was missing from your earlier info, sorry.
   / Tractor won’t start tonight. #25
Sometimes (on my Mahindra) I have to press the clutch peddle really hard and several times when it's really cold out.
   / Tractor won’t start tonight. #26
Agree with most of the above but he has bright headlights while attempting to crank the engine -unless i read it wrong.
The headlights would go completely dim while cranking if that were the case (bad battery) plus he also used a booster and no crank.. from previous description it sounds like the starter solenoid and therefore bendix/starter windings is not being energized.
I would put a voltmeter on the solenoid start terminal and hit the key to see if the solenoid is seeing "start" voltage. a bad connection like the main ground or a safety switch that is not allowing the solenoid to be energized or even a bad key switch. Another volt test is put the volt meter across the battery ground at the battery and the starter case and if while attempting to crank, Voltage suddenly appears a weak ground is indicated.
If the solenoid start terminal does not see a Voltage when trying to crank then a voltage applied to that start terminal after all safety precautions are taken to make sure the tractor does not move and cant run over the tester. If it turns over something is interrupting the start terminal circuit path
If the solenoid does see Voltage at the start terminal and main power at the starter is verified while attempting to crank, a starter problem is most likely. my 2 cents
Well… again I really want to thank everyone who has read this post and truly appreciate everyone who has replied.
Long story ending is this… Still no bueno on getting her started!
Here is what I did:
Turned the key to Accessory position to turn everything on. Tail lights come on, brake lights come on when the pedal is pushed.
Monkeyed around with every lever in the cab as well as every plug I could find outside and under her. I tried to start her after every ‘Monkey Movement’.
Did the old ‘screwdriver across the starter’ and she turned over BUT did not start. Ran (drove) to town and eventually put a 950CCA battery in her. Crossing my fingers the entire trip but she still would NOT start.
I decided to remove the entire dash/steering housing so I could look at the guts underneath. Found the brake safety switch. Doused it with WD40 and worked the contact pin up and down for a while because I know how to do that! Found it very odd that when I apply the brakes and lock them with the Brake Lever, the brake safety switch PIN (which travels in and out of the switch) is actually in the OUT position. Anyway, she did not start.
Next I disconnected and reconnected both forward and reverse pedal switches underneath. Still nothing!
After all of this I decided to just do the old “screwdriver across the starter’ and with the new battery (I am guessing) she roared right up. I know this does not solve the issue at hand but I really needed to move some more snow so my wife could make it onto the property and get home.
Maybe in June or July I will trace the ignition (Start) wire from the key to the starter and see what is in between.
It’s -5 degrees tonight so July sounds great!
   / Tractor won’t start tonight. #28
Thanks for the update and glad you were at least able to get a temporary method to start her. So I would also surmise that you are getting power to the fuel solenoid when you are "jumping the starter" because she starts and will continue to run.
Maybe it something with the key switch? A electrical schematic would sure help in identifying what to look at next with all the information you have so far.
   / Tractor won’t start tonight. #29
Do you have a starter relay? The one on my 2538 failed and had to be replaced. Mine is on the left hand side just behind the battery. Edit: it bench tested fine but would not engage the starter. 20220905_190853.jpg
   / Tractor won’t start tonight. #30
I'm late to the party, but check your grounding cable from the battery to the frame. If you can jump the starter, then your problem appears to be between the battery and the starter. Including relays, as mentioned above, as well as safety switches (hate the damn things).
On a different thread a guy mentioned a safety switch by the rear axle next to the tire. Small gauge wire that had come unplugged while he was working with the tractor. I never would have thought to look there.
2015 Toro Reelmaster 5510D Fairway Commercial Reel Mower (A56857)
2015 Toro...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
TOOTHED BUCKET FOR MINI EXCAVATOR (A58214)
TOOTHED BUCKET FOR...
2008 Ford Ranger Pickup Truck (A54814)
2008 Ford Ranger...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A52709)
KNOW BEFORE YOU...
LOT: (5) Bolt Cutters (A59076)
LOT: (5) Bolt...
