Tractor tires for winter
/ Tractor tires for winter #1
BCE3
PEPPERELL MA
B7500
I have a older Kabota B7500 with the original ag tires on the front and back, use chains for the back but the front are always slipping in the ice and snow .
I was wondering if a different tire would help in this situation ? Can you put two different type of tires on the front than the back ? This is a 4 wheel drive tractor
Thanks for your help
B C
/ Tractor tires for winter #2
Can't answer your question but if there's tread on the tires you have let air out of them so their soft and they'll probably work as good as any tire. You can also buy studs and screw into them or chains.
/ Tractor tires for winter #3
You can put chains on the front. Just some for a light truck. I probably have ten sets or more. All came from yard sales, thrift stores, pawn shops. Some are brand new, bag still sealed when I got them. Maybe four sets new. Whopping 5 bucks a set.
/ Tractor tires for winter #4
You’ll probably always having steering issues on packed snow/ice just becsuse there’s so little weight on the front. Even if you have a front snowblower, the blower is usually in float, so there’s not much yo push down on the tire.
As the others have suggested above , chains on the front should help, but it will never be like driving on a dry surface .
/ Tractor tires for winter #5
I suspect this will start a discussion as many opt for putting chains on the front.
My dealer strongly recommended against this when I asked about it several years ago. I have aggressive ice chains on rears but thought of putting chains on front.
They said no. With the " front lead" the front wheels want to slip a little. The extra traction and right conditions can stress the front system. So I chose not to and actually I get by just fine. I work in the woods in rough conditions.
Others use front chains with no issues.
/ Tractor tires for winter #7
Consider grooving or sipping tires? Tires need edges for traction.
Had well worn R4 tires on my M59 when I bought it. Slipping bad on side hills and mud. Used a angle grinder with a chainsaw carving blade to groove.
Made significant difference.
Did similar for the B26 fronts for mowing grass on hilly terrain. Hot knife regroover. Homemade R14 type on a heavier tire.
Others have had improvements in snow/ice traction from grooving.
/ Tractor tires for winter #8
I agree with this. I deal with significant ice on my steep driveway in the spring. I have a set of studded diamond pattern chains and I don't have any issues getting anywhere. There is some lateral sliding on the front but there is very little that will stop that from happening.
/ Tractor tires for winter #9
I used V chains on the front wheels only of my first small tractor for 30 yrs. with no ill effects. It's only been the last few yrs. I have them on the back wheels.
/ Tractor tires for winter #10
Do studs do anything noticeable to asphalt driveways? I've heard chains do. I might consider studding my R4s to reduce possible pucker events on ice.
Thanks for your post , great idea !
/ Tractor tires for winter #13
Easiest and perhaps best solution - chains for the front tires. I run R-1's year round on my M6040 and have not found a need for chains - yet. Besides a good set of those European type ( Aquiline Talon ) are so God-awful expensive. Last I checked - around $4000 combined cost for front & rear.
/ Tractor tires for winter #14
I like the looks of that! It has to help! Might do that one of these days!
/ Tractor tires for winter #15
I put chains all around. It goes where I point it.
20190216_131858-jpg.733560
/ Tractor tires for winter #16
I have 2-link chains for all four corners, the usual 1/4" stuff for fronts, and heavy duty chains (5/16" or 3/8"?) for the rears. I hate moving those rear chains, honestly.
Turf tires grip great on my asphalt drive for plowing, and even do well enough around the yard in moderate snow depth (eg. up to a foot). In fact, I wouldn't want to run chains on asphalt, as they just slip and chew up the surface. But if I need to pull a trailer or wagon around the yard thru deep snow, then I chain up.
2014 Ford F-250 Utility/Service Truck, VIN # 1FDBF2A67EEA87424 (A65563)
2014 Ford F-250...
2019 CASE CX57C EXCAVATOR (A65053)
2019 CASE CX57C...
2017 Ford F-150 Pickup Truck (A64556)
2017 Ford F-150...
213324 (A64279)
213324 (A64279)
2016 Chevrolet Express 2500 Cargo Van (A64556)
2016 Chevrolet...
2001 Ford F-550 (A66408)
2001 Ford F-550...
