Tractor Skid Steer Quick Connect
/ Tractor Skid Steer Quick Connect #1
michellesc7
Western SC and Eastern SC
John Deere 5410 4wd Cab w/ loader, Mahindra 6500 4wd Q/A FEL, John Deere 4120 4wd w/ FEL & John Deere 1050 4wd
Hi Y'all
Yes I killed my quick connect attachment for my loader on my Mahindra 6500-this past weekend. I am looking at a universal unit from HaySpear. I want something heavy duty.
I believe I caught the corner of my wide bucket on a cherry tree and heard a pop as I pulled backwards. (I was in a bottom area and there may have been a difference in height slightly also.) The manufacturer's replacement price I recieved was about $750 with shipping included in it. It is worth about $500 to me. The hayspear model is about $475-have not checked on the shipping.
Any mutual experiences out there? I'd like some with a couple of cross braces along the width. Internet search did not do well.
Michelle from SC
Romy Farms
/ Tractor Skid Steer Quick Connect #2
Is it possible to have the damage repaired with some extra reinforcement where it failed?
I have not gone that route. The middle of the device (thin steel) is twisted. I do think the ends could be cut off and a new piece of plate steel could be welded between the two quick connect boxes. Maybe I need to investigate that.
Michelle
/ Tractor Skid Steer Quick Connect #4
Hi Y'all
Michelle from SC
Romy Farms
Here is a link to the one I'm looking at for my Deere. Skid Steer Q/A Adapters for Frontend Attachments
/ Tractor Skid Steer Quick Connect #5
Michelle,
Can you post a picture or two? Front and side views would be helpful to us so we could offer you other alternatives than just replacing...
I have not made time to take pictures. I did load up the skid steer quick connect and take it to a fab shop. The owner looked at me and said I was going to challenge him. So I am taking the risk that he can fix the robust twist and add a little more steel to the unit.
Otherwise I am looking at min $600 to $800 for a unit that still might twist next time I get the bucket teeth caught up in another cherry tree- which is what I have figured I had done- not head on but on one end and the movement backwards caused the twist. I was not on perfectly level ground, I was working in the ruts caused by the 4 wd treads. So this is my documented story that I share with you. I guess I am assuming and betting the fab guy is good enough to fix it. He did say he would put the experienced older guys on it.
Let you know what happens. I may eventually get my other tractor loader set up with skid steer and if I go that route I will buy the boxes offered with the flip levers and get someone to weld me some C Channel between the boxes. What I found on the internet was 3 by 3s (1) and 2 by 3s(2) on the pricier models - I like C Channel.
Michelle
2016 Ford Explorer AWD SUV (A59231)
2016 Ford Explorer...
2020 Vermeer Vac-Tron LP873SDT T/A Vacuum Trailer (A59228)
2020 Vermeer...
8ft Flatbed Truck Body with Axle (A55851)
8ft Flatbed Truck...
12ft 5in Flat Bed (A61165)
12ft 5in Flat Bed...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2019 INTERNATIONAL...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
