Tractor Skid Steer Quick Connect
/ Tractor Skid Steer Quick Connect #1
michellesc7
Western SC and Eastern SC
John Deere 5410 4wd Cab w/ loader, Mahindra 6500 4wd Q/A FEL, John Deere 4120 4wd w/ FEL & John Deere 1050 4wd
Hi Y'all
Yes I killed my quick connect attachment for my loader on my Mahindra 6500-this past weekend. I am looking at a universal unit from HaySpear. I want something heavy duty.
I believe I caught the corner of my wide bucket on a cherry tree and heard a pop as I pulled backwards. (I was in a bottom area and there may have been a difference in height slightly also.) The manufacturer's replacement price I recieved was about $750 with shipping included in it. It is worth about $500 to me. The hayspear model is about $475-have not checked on the shipping.
Any mutual experiences out there? I'd like some with a couple of cross braces along the width. Internet search did not do well.
Michelle from SC
Romy Farms
/ Tractor Skid Steer Quick Connect #2
Is it possible to have the damage repaired with some extra reinforcement where it failed?
I have not gone that route. The middle of the device (thin steel) is twisted. I do think the ends could be cut off and a new piece of plate steel could be welded between the two quick connect boxes. Maybe I need to investigate that.
Thanks
Michelle
/ Tractor Skid Steer Quick Connect #4
Hi Y'all
Michelle from SC
Romy Farms
Here is a link to the one I'm looking at for my Deere. Skid Steer Q/A Adapters for Frontend Attachments
/ Tractor Skid Steer Quick Connect #5
Michelle,
Can you post a picture or two? Front and side views would be helpful to us so we could offer you other alternatives than just replacing...
I have not made time to take pictures. I did load up the skid steer quick connect and take it to a fab shop. The owner looked at me and said I was going to challenge him. So I am taking the risk that he can fix the robust twist and add a little more steel to the unit.
Otherwise I am looking at min $600 to $800 for a unit that still might twist next time I get the bucket teeth caught up in another cherry tree- which is what I have figured I had done- not head on but on one end and the movement backwards caused the twist. I was not on perfectly level ground, I was working in the ruts caused by the 4 wd treads. So this is my documented story that I share with you. I guess I am assuming and betting the fab guy is good enough to fix it. He did say he would put the experienced older guys on it.
Let you know what happens. I may eventually get my other tractor loader set up with skid steer and if I go that route I will buy the boxes offered with the flip levers and get someone to weld me some C Channel between the boxes. What I found on the internet was 3 by 3s (1) and 2 by 3s(2) on the pricier models - I like C Channel.
Michelle
2022 CATERPILLAR 299D3 XE SKID STEER (A65053)
2022 CATERPILLAR...
2018 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59904)
2018 INTERNATIONAL...
UNUSED 4' X 300' ROLL ATS POWER GRASS PROOF CLOTH (A64281)
UNUSED 4' X 300'...
John Deere LX5 5ft. Rotary Brush Cutter Tractor Attachment (A61572)
John Deere LX5...
6 Row Harrell Stalk Chopper (A62177)
6 Row Harrell...
2017 TROXELL 150 BBL ALUMINUM VACUUM TRAILER (A63569)
2017 TROXELL 150...
