Tractor side SS quick attach build
/ Tractor side SS quick attach build
I removed my cylinder brackets from my bucket and reused them on my SSQA , for me it was just as easy to do that then build a new set. Also using a plate is a good idea, I had a set of factory built pallet forks a friend loaned me, and used them , made a real nice jig for fitting and tack welding together and everything I've hooked to so far has fit really nice.
:thumbsup: +1 on reusing the existing cylinder brackets. I could not reuse them on my Montana but did so on a 'bota L3400. The Kubota worked out perfect. That Kubota bucket had a lot of really nice welds! ;) I made a post about that installation here also.
/ Tractor side SS quick attach build #43
Have you patented this build, and if so, have you licensed it out for manufacture? It is definitely marketable.
2019 KENWORTH T880(INOPERABLE) (A60736)
2019 KENWORTH...
1993 20ft. Custom Deck Over Equipment Trailer (A56857)
1993 20ft. Custom...
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
2017 Freightliner Cascadia 125 T/A Sleeper Cab Truck Tractor (A59230)
2017 Freightliner...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2007 Ford Ranger Pickup Truck (A59230)
2007 Ford Ranger...
