Tractor recommendations?
/ Tractor recommendations? #1
kirkmcquest
vermont
JD
Hello. We are in the process of growing our farm and branching into some new avenues and are hoping for some advice on tractor makes and models. We might be acquiring some 80/90 acres of good pasture/field land.
Right now, as more or less "homesteaders" we have made due with our JD 4700 diesel. We do a little haying ( about 5-7 acres ), plow/till about 1 acre, plow snow, move things around etc with that tractor. I don't think it will be enough for the new property, so we're thinking to go bigger with this tractor.
What type/size make/model tractor would you recommend? We will be buying used. The new property means we will be haying about 40 acres, but also cutting alot of timber, plowing snow, driving posts, plowing/tilling/cultivating and etc with that tractor.
__________________
/ Tractor recommendations? #2
Welcome to TBN--join the fun:D
I'd start looking in the 50-70 hp (engine) range for that size property and for the jobs you're planning to tackle. Shuttle shift, at least 3000 lb lift on the 3 point hitch, FEL with 6 ft bucket and 3000 lb lift. All the major tractor manufacturers have models like this.
Find a local dealer that has a well stocked parts department and a good service facility.
Good luck.
/ Tractor recommendations? #3
jd 5410,5420,5510,5520 preferably with a power reverser.mfd is nice.i would add rear wheel weights or cast centers.
/ Tractor recommendations? #4
as said you want a min 70hp tractor 4x4 fel.an you may even want an 85hp tractor.
/ Tractor recommendations? #5
Kubota M sized in the 70-90HP range or a deere 5xxx series would be two good places to start. That will give you an idea of sizes, prices, and features. They you can cross compare to New holland, or Kioti, or Mahindra, or LS if you have dealers in your area.
2006 STERLING AT9500 6X4 T/A 14FT DUMP TRUCK (A59910)
2006 STERLING...
2020 Peterbilt 567 Quint Dump (A62613)
2020 Peterbilt 567...
New Holland 354 Feed Grinder (A64047)
New Holland 354...
Arrow Quip 10' Heavy Duty Bow Gate (A64047)
Arrow Quip 10'...
JMR mini trailer mover attachment (A61567)
JMR mini trailer...
2007 FREIGHTLINER M2 106 4X2 26FT BOX TRUCK (A59910)
2007 FREIGHTLINER...
