Tractor problems
/ Tractor problems #1
lesterjanet
Kabota L2850
:confused2: We ahve a Kabota L2850, it developed a leak in the hoses and now the oil filter is leaking and has a hole in the bottom. we are haveing problems taking the filter off, and how do we find the type of filter to replace it with?
/ Tractor problems #2
Hello lesterjanet, welcome to TBN! Glad to see you posting. Hope you enjoy being a member of our community. :)
/ Tractor problems #3
You'll need to get it from a dealer... do you have any near you? You can mail order them if you need to. What size holes? Oh, and welcome to TBN :) The hose can be replaced by most hydraulic shops and sometimes even NAPA stores (at a higher price.)
/ Tractor problems #4
How old are the hoses? Hoses can get old and crack but usually only after a good deal of time. The hole in the bottom is a little more interesting. Is it possibly rusting or does it look like it has been punctured? As far as the filter goes I would call your closest dealer and if there is not one close a lot of major auto parts stores can cross reference the filter for you. Getting it off isn't too bad. You may want to get an oil filter wrench if you are going to keep doing your own maintenance and don't have one yet. If you cant get access to one, a messy way to do it is to pound a screwdriver through the filter to give you leverage. Caution it will be messy. When you finish remember not to overtighten the filter. You should not need a wrench to put it back on.
/ Tractor problems #5
I have seen a few other posts suggesting people look at tractorsmart.com for parts and manuals.
I would NOT try the screw driver method, often when you go to turn the screw driver all you do is cut the filter in half. You have a real mess then. I think even Wal-Mart carries oil filter wrenches.
/ Tractor problems #6
Welcome to TBN!!! If you need any additional information, you might want to try the parts/repairs or hydraulics section.
/ Tractor problems #7
Welcome to TBN.
You are definatally better off getting a filter through a dealer.
The hoses can be made at any hydraulic shop if you have any around. It is best if you take all of your old hoses in and they can make them exact. But be warned, hydraulic hoses aren't cheap.
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
BUSHHOG 2615 LEGEND BATWING MOWER (A63276)
BUSHHOG 2615...
2021 VERMEER LP573XDT VACUUM TRAILER (A63276)
2021 VERMEER...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63118)
2023 Unverferth...
2020 FREIGHTLINER CASCADIA CA125SLP 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2020 FREIGHTLINER...
2025 44in Hydraulic Grapple Mini Skid Steer Attachment (A61572)
2025 44in...
