Tractor position on the trailer
/ Tractor position on the trailer #1
Goreef
Smithville Texas
mahindra 6530 4x4 2013 .Bought at J5. Great dealer,i would highly recommend
I have a 24 foot gooseneck with dual 10k axles and a 1 ton single wheel chevy duramax.My question is i need to haul my tractor that weighs 7500# to the shop and i dont know how far foward to put the tractor on the trailer.
/ Tractor position on the trailer #2
Are you serious here? With that setup you could put the tractor just about anywhere and not run into problems. Get the center of the weight of the tractor just a bit forward of the trailer axles and chain it down and go. You will hardly know it's on the trailer.
Im dead serious LOL. I have never pulled the trailer with that much weight on it so i guess im just a bit paranoid.
/ Tractor position on the trailer #4
What I started doing is measure the distance between the truck's rear bumper and the ground before loading the tractor. I then drive the tractor forward on the trailer until the truck squats an inch or two more, as indicated on the ruler. What you want to avoid is too little tongue weight, so even if you don't do the ruler thing, err on the side of pulling too far forward. Like PMS said, your trailer is golden.
/ Tractor position on the trailer #5
Place the tractor in trailer where the centre of gravity falls near the axle of the trailer. You should go fine with that.
i like your methodology thats kind of what i had in mind, I did a trial run the other day and when i put the rear tire of the right over the forward most axle on the trailer. when i checked the truck it squatted it to where the overload springs were just starting to touch. I think this is the sweet spot where the truck has a decent amount of weight over the axle.
/ Tractor position on the trailer #7
Don't go all the way up you have to much tounge weight!I.stay back a little of the 2nd wheel well not much but alittle.
/ Tractor position on the trailer #8
This is exactly what I do. Pull forward til the helpers are just touching. Tows great like that with my bumper pull.
Massey Ferguson 285 Tractor w/ Loader (A66285)
Massey Ferguson...
2022 EZ-GO ELITE...
KBH Tender Trailer (A63689)
KBH Tender Trailer...
2011 CASCADIA 6X4 T/A DUMP TRUCK (A59914)
2011 CASCADIA 6X4...
2021 PETERBILT PB337DUMP TRUCK (A63276)
2021 PETERBILT...
2020 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A65053)
2020 CATERPILLAR...
