Tractor options for plowing
/ Tractor options for plowing #21
Thanks for everyone's input. After comparing tractors in this class from JD, NH, Kioti, Kubota and LS (brands local dealers carry) I decided to buy an LS. Getting an XR4155HC with 8' blade. I really liked it driving it around the dealership. After driving the LS I just couldn't personally justify spending $9k and up more for the bigger names and $2k more for the Kioti. It may not plow as fast as a truck but I won't be rebuilding the front end every 2-3 years either.
I spent 4 years travelling through 9 States and Provinces representing a Canadian snow plow manufacturer and have spent another 4 years working closely with snow removal contractors and heavy equipment dealers. The consistent issue I had with LS dealers (Branson, Mahindra, Kioti) was that in their aim to compete on price they would but the wrong kind of plow on a FEL. Regardless of manufacturer, FEL are expensive to repair and from the description you gave of the road you are plowing I sincerely hope they provided you with a quality 8' blade with a real trip system. If not your warranty will not cover damage to the FEL and it won't take much with a 55HP tractor to cause it.
That being said, enjoy your new tractor.
/ Tractor options for plowing #22
I was somewhat in your shoes. I plowed my private road (3/4 mile) for years with beater yards trucks. I got sick of buying/fixing/selling the trucks so I bought a Tractor with a cab. I ended up with a LS 4140HSC. I used one of the 7.5' plows from one of my old trucks and mounted it to a QA setup. I ran the hydraulics from the rear remotes to pivot the blade from side to side, I also found a rear mount blower 72" with an additional 6" of wings. I normally use the mid gear and find it works well, but is no where near 9-10MPH, maybe 3-4MPH. The snow doesn't roll off like the truck did. I had to change the way I plow. I wouldn't go back to a truck at this point. I can get the road MUCH wider with the tractor. What I have found myself doing with any snow over 6-7" is to plow the snow into the center of the road, then blow it into the woods on my last trip. IMG_9779.jpgIMG_9781.jpg
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
PORTA POTTY (A67714)
2018 CATERPILLAR 573D FELLER BUNCHER (A64276)
2018 CATERPILLAR...
335 GAL WATER TANK (A68842)
335 GAL WATER TANK...
2018 Ford Explorer AWD SUV. (A66738)
2018 Ford Explorer...
2025 Pallet of Miscellaneous Duplex Polyester Webbing Slings (A66734)
2025 Pallet of...
