Tractor modifications
/ Tractor modifications #21
Don, I agree about the computers and plastics on a tractor. I like a steel hood myself as for the them rusting they usually last longer, Ive never run many machines with a plastic hood, and ive had other operators bend the steel hoods but they didnt give a rip about the machinery. Computers dont react well to ecessive heat ,dust, vibration,accidental gouging and such as on a good hard used tractor. Alot of excavators use computers but they arent jarred as bad as other machines.
One thing You could to to protct the tractor is to have a spill guard like a wheeled/tracked loader has to hold rocks back. One thing that worries me is the mass above and how a rock tends to roll or bounce down loader arms. One thing if you dont mind me asking is can you get the tractor on top of the cliff, if you can then use the hoe to dig down as far as you can with it and just let the material fall as you scrape it off and dump it then drive the tractor back down and use the loader to load the loose stuff then you can use the hoe to rake the remaining bench down. I had a good friend break his back on a hill like yours digging it out with a full sixed hoe, it just takes one 50 pound rock from that height.
/ Tractor modifications #22
That's quite a reach for your loader! No wonder some of the loose stuff pops down when you are digging up there. If you are really into doing it with your tractor, bringing in a couple truckloads of clean fill could give you about a 2-3 ft ramp to work from so you aren't right at the limit for the loader. Of course you'd have to move the dirt ramp as you worked your way along the bank. Overall, it would probably be a lot quicker to bring an excavator in for 1-2 days to knock the thing down.
/ Tractor modifications #23
After seeing your picture, I'm certain your 4700 is not the tool of choice, but rather the tool of opportunity. I have some areas on my property that are very similar to yours, maybe even higher. I just refuse to use my tractor in that situation because I know I would destroy it. It's a hard decision, and I'm trying to be more sympathetic than judgemental, but I think that rock through your hood is a warning of things to come. You probably need a full reinforced cage around your operator's platform. Ultimately you have to make the decision on the amount of risk.
Now about your tractor... Is that plastic or fiberglas? The hood and fenders on my New Holland are fiberglas. I got a limb between my rear tire and fender and it made a 1/2" (marble sized) break along one edge and I can clearly see the fender's innards are fiberglas. Considering that the Chevrolet Corvette has used fiberglas since 1954, I think fiberglas has shown itself to be long-lived when exposed to the elements. I am very happy for the fiberglas in my tractor and I love computers too. Where would air travel, manufacturing, and communications be without computers? Anything can be abused. It's not the object, but the person in control of it that makes it good or evil. ...okay, I'll quit lecturing. /forums/images/graemlins/tongue.gif /forums/images/graemlins/laugh.gif /forums/images/graemlins/laugh.gif
/ Tractor modifications #24
yea the corvette was plastic since the 50s but how often do ya see a corvette in a gravel pit or bouncing around a logging road and getting sticks jammed into the wheelwells. i am sure that if henry ford had a fiberglass hood on his 8Ns that there would be alot fewer of them around now, once the hood fell apart and the tractor sat out for a few years everything on the engine wouldnt be protected and would soon get messed up too. the beauty of those early tractors is that most everything, even the seat, was metal, so the only thing that was plastic and went bad over 50 years or so was the wiring which was relatively easy to replace.
/ Tractor modifications #25
</font><font color="blue" class="small">( yea the corvette was plastic since the 50s but how often do ya see a corvette in a gravel pit or bouncing around a logging road and getting sticks jammed into the wheelwells. )</font>
You may not see Corvettes on logging roads. But you do see log trucks on logging roads .Nearly all have fiberglass hoods.
Many gravel pit trucks use fiberglass hoods and body panels and they hold up very well under rough conditions.
Most over the road trucks that can see millions of miles over their lifetime running fiberglass hoods and body panels.
/ Tractor modifications #26
Don, is it possible to work from above with the BH? I have a small gravel pit and have had good luck removing vegetation/subsoil first and then loosening the gravel and using the BH to push material over the edge. Bill C
/ Tractor modifications #27
<font color="blue">"I spent 30 years designing computers. For the first 20 years they were used for good things but in the last 10-15 years they have become too powerful and pervasive. After I saw what the government was doing with the supercomputers we designed I have learned to fear them. As for the good they have done just try to buy something when the store's computer is down. The real threat is total loss of freedom and privacy - something that our citizens seem to be more than willing to give up.
I did not say I was a computer hater. I just think the world would have been a lot better off in the long run if they did not exist." </font>
Don, that's beautiful. It almost makes me cry.
I agree about the excessive dependency on computers.
Just go to any McDonalds, Hardee's, etc. and order something that doesn't have it's own button. Geez....
We have officers that can not function when the computers go down. They don't know what a hand-written report is!
On the flip-side...
Without computers, we wouldn't have TBN. /forums/images/graemlins/frown.gif
/ Tractor modifications #28
Centex,
Glad to hear you got your perimeter secured.
As for the phd I got from you it works great in most areas around my place. The only thing it won't do, as you well know, is go through bedrock. It does shear pins quite often in gravel soil, and anything bigger than the space between the flutes is pretty much a no-go. All in all I'm pretty happy with it.
A funny story about that, though. I used it to fence around my two garden areas. Checked the map for water line easements and something didn't quite match up, because the water meter was in a different place than they showed. Oh, well, started my first hole with my new digger and promptly hit my water main at 2'. It wouldn't have been so bad, but my in-laws were there and the video tape was rolling to capture this momentous event. /forums/images/graemlins/blush.gif
No big deal as the line was pvc. Fixed the line after running to the store and then set the posts.
However, I can't help but notice that your plastic hood was broken by a rock whereas my plastic water line was broken after drilling through rocks with a phd I bought from you. /forums/images/graemlins/shocked.gif
(Fade to black with Twilight Zone theme playing softly in background) /forums/images/graemlins/smile.gif
/ Tractor modifications #29
<font color="red"> With metal I could just drag out the body tools and with a little (realy a lot) of work I could have back to like new. </font>
To me time is money. Downtime is worth something, is it not?
With the time and materials to make your metal hood look new again, I am sure it would have cost more than the $210.
$210 and about an hour, you are up and running with a new hood. No paint to buy, no sanding, priming, sanding, painting, reinstall ect...
/ Tractor modifications #30
When or if you order your new hood, do not forget to order the applicable decals as well. I ordered a new hood for a JD garden tractor and was surprised when I pulled it out of the box.
/ Tractor modifications #31
But the real open pit mining trucks are made of all steel. I remember when I brought this topic up in the JD forum and most people liked plastic. Looks like things have taken a swing back to metal. I find that in some places plastic does have advantages. Even in my 990 the very tip of the hood is plastic not metal like the rest of everything. I had a very small scratch there and it came right out using 3M wax. It is all a matter of personal preference.
"Did you check your battery for damage ? Whatever it was that ruined your tractors hood might have cracked the batteries case ."
All that was broke was the hood. The rock that broke it was only fist size. A lot of large rocks have bounced off it with no real damage but this one hit just right and the hood just shattered. I never noticed just how thin an flimsy the plastic in the hood is but now I am supprised that some of the limbs that have it before did not break it.
"JDParts shows a price of $210.00 for the 4500/4600/4700 hood (P/N LVU12063)."
That's good news. Only $210 for a part that cost JD maybe $20 or so. I expected a larger markup. I wonder how much the two decals will cost. I hope less than the hood.
"One thing if you dont mind me asking is can you get the tractor on top of the cliff?'
I wish there was a way to get up there but there isn't. Actually I am being very careful not to let large rocks fall. If I see any chance of anything of size moving I take full advantage of the hydro transmission to get away at full speed. I use digging bars on top of the hill to dislodge the large rocks so there are none near the edge where I am digging. I have dug down to a solid rock ledge at the base of the hill so when a 3000 pound boulder falls 14 feet from the top it shakes the ground. There is no doubt in my mind what they would do to anything that was in their way.
"Now about your tractor... Is that plastic or fiberglas?"
I believe it is ABS. It is definitely not fiberglass. I owned a Corvette for 30 years and I had much large rocks bounce off it with out doing any damage other than paint dings. One bounced of the hood and came through the windshield. It only made a tiny ding in the paint although it made a lot noise when it hit but then it was glancing blow to the Corvette hood whereas the rock that broke the tractor hood made a direct hit and transferred all of its energy to the hood. I don't know if the fiberglass would have survived if it took a direct hit but it would not have shattered into small pieces. The other thing in the fiberglass's favor on a Corvette is that it is protected from UV light by paint. I doubt seriously that a plastic tractor with molded in color would survive thirty years in the sun.
"To me time is money. Downtime is worth something, is it not?"
You get a different perspective when you are retired although I have always hated to throw anything away. Money is now something to be hoarded for really necessary things and time is something you have a lot more of to spend. I drove the same Corvette for 30 years and it was not my oldest vehicle. I have 1934 International PU truck that is made out 18 gauge metal in the body and 10 gauge in the bed. The bed has dents that I have never been able to beat out but I prefer to look on them as patina.
/ Tractor modifications #37
Right you are steve on the comparison cost of repairing a metal hood vs replacing a plastic/fiberglas hood. But what about 20 years from now when the hood has been discontinued......
/ Tractor modifications #38
Plastic can be saved, if you have a similar remnant. I punched a hole in a plastic dirt bike gas tank one. Broke the front fend, which was the same plastic. A guy used a hot air gun of some sort, and used the fender material to "weld" the hole in the gas tank. Worked perfect...
"Plastic can be saved, if you have a similar remnant."
Not the stuff that John Deere uses! It shatters into small pieces. Of the missing area there were about 50 small pieces that I found. I even found a handful of small pieces in the air cleaner.I have repaired many plastic items by using a small wood burning iron to melt them back together and using similar plastic as filler rod but not this type of plastic.
I was at my dealer's yeaterday to pick up the $165 worth of oil and filters to do the 400 hour service. They had another 4700 in to have its hood replace for the same reason so mine is not an isolated incident. I priced the extra armor kit and it is $615 so I guess I was better off just replacing the hood since it is not all that much more than an oil change!!!!
/ Tractor modifications #40
The components of the kit are also available for individual purchase to meet specific operator needs. See how much just the hood guard costs, if it's reasonable it could save you money in the long run.
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A61573)
2021 Mercedes-Benz...
2006 Stephens Aluminum 407 T/A Chemical Tanker Trailer (A68183)
2006 Stephens...
2021 WEILER K560 KNUCKLEBOOM LOADER (A65057)
2021 WEILER K560...
2017 Ford Explorer AWD SUV (A66738)
2017 Ford Explorer...
2004 Jeep Wrangler X 4x4 SUV (A61574)
2004 Jeep Wrangler...
2009 WESTERN STAR 4900 SF WINCH TRUCK (A67714)
2009 WESTERN STAR...
