Tractor Literally shaken apart!
   / Tractor Literally shaken apart! #21
john_bud said:
Alan,
I HAVE to ask, Why don't you rent pigs?
jb
I think I can answer that for Alan. Do you remember "Lonesome Dove", and the Hat Creek Cattle Company sign? The sign included the line "We don't rent pigs" because, as Gus said: "Well, we don't rent pigs, and it's better to say it right up front ..."
   / Tractor Literally shaken apart! #22
bbse said:
As for the bolts vibrating loose, I think I would just drill the heads and safety wire them together. It worked on B52's :D
There is an aircraft mechanic if I ever saw one. Where are ya/were ya stationed and what branch.
USAF Charleston SC. C141b
   / Tractor Literally shaken apart! #23
I was in the 98th Bomb wing 8th Air Force SAC. I was Station in Warner Robbins GA, for most of my time. Also spent a number of years on C130A in the 118th Tactical Airlift Wing TN Air National Guard. I was a crew chief the whole time so preventing loose bolts was a main part of my job. Safety wire was the way we kept those bolts in. It is amazing how smooth an 8 engine bomber is and how fast a bolt would fall out if it was not secured.
That pretty much says it. As long as I put it up front there that I don't rent pigs, then people won't be asking me to rent them a pig. Saves time and trouble. As Gus said. Of course, the reason I don't rent pigs is that I don't have any pigs to rent.
   / Tractor Literally shaken apart! #25
Alan, I hope you were mistaken about cleaning everything up with "brake fluid", that stuff will eat off the paint and possibly swell the gasket if it's not designed for use with brake fluid. I think the suggestion was to use brake cleaner. Just wanting a little clarification.
   / Tractor Literally shaken apart! #26
ccsial said:
My rule is simple. If you borrow my tractor I throw in the operator. ME.
Here here - I even get nervous lending out a Harbor Freight socket set... :)
However - When the huge snows hit Buffalo - I let my BIL (who has a reputation for destroying things) - borrow our generator... warned him, explained the expiations and let it go... It came back fine. I am now sleeping again.
   / Tractor Literally shaken apart! #27
I believe B2710 with KK 60" tiller is not suitable for very hard, dry clay.
   / Tractor Literally shaken apart! #28
I was a recip mech. Lots and lots of saftey wiring! C-124s were the worst. Remember ole Shakey?
   / Tractor Literally shaken apart! #29
The C124's were well before my time. I got to work on a C7 one time but it was headed to the boneyard then. I don't think I ever worked on a recip. When I was in teh Guard I had a chane to work transient alert and do tramp duty. Serviced some cool stuff there. F15's, F14's, Gulfstreams,Lears,KC135. But it was long enough I have forgotten most of it anyways.
   / Tractor Literally shaken apart! #30
Wow, deja vu.
   / Tractor Literally shaken apart! #31
Can't belive this thread is that old. Realized I never replied.
I worked on C141s but they brought in an old Shakey (C124)for the air museum at Charleston AFB while I was there. It was something. The old timers had lots of stories about it(like 100 yard cables).
   / Tractor Literally shaken apart! #32
Safety wire; unless you are going to give lessons on how to properly install the wire you better suggest they stick with locktite. Use to work for a major mfg company who used safety wire on some bolts. Amazing how often they would end up with them not run to keep the bolts tight.
As to the vibration of bolts, got on excavator Saturday, noticed bolt on end of tubing missing. Not much vibration there but had to replace before running machine. At same spot about two years ago parked tractor to talk with one of my BIL and one of us noticed bolt about to fall out of starter on tractor. Very little vibration on that machine also. By very little I mean nothing like your's was subjected too, just normal use. The tractor had been pulling a disk and the excavator piling wood to burn. Nothing like trying to get dirt out of bucket.
It is possible when you found one issue you did a careful over view and picked up issues from other times. But on the knob, mine (Kubota also) have a clip through the end to prevent their coming out. I am 100% sure on one tractor as I notice it last week and thought great idea, not sure on other tractor but they will not screw out either.
   / Tractor Literally shaken apart! #33
Man, a two year old thread born again. That is funny. As to using safety wire, it most definitely would be a last resort. You are right about knowing how to use it, main thing is the bolt heads would have to be drilled. It may not stop a bolt from from losing torque but done anywhere near right, it would not turn out but a fraction and would not fall out.
Of course our main concern with tractors, usually, is not vibration but stress. Shearing bolts under load in heavy equipment is more of a problem than vibration. Use good grade 8 bolts and lock washers with Loctite and that normally is enough. If the threads are overstressed or part is soft then oversizing the holes may be the answer. It is what I had to do on one of my tractors from end steering housing bolts.
   / Tractor Literally shaken apart! #34
   / Tractor Literally shaken apart! #35
I worked on them at Charleston.:( My last permanent station.
   / Tractor Literally shaken apart! #36
Well, I learned it as "you can pick your friends and you can pick your nose, but you cannot pick your friend's nose"!:p
That's correct. I think the other saying simply says you can pick your friends, but you can't pick your family.
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
HYD BREAKER HAMMER (A60429)
HYD BREAKER HAMMER...
FORD 8630 TRACTOR (A60430)
FORD 8630 TRACTOR...
(2) NOS-8 LUG- 7000Ib 74SC-93 HUB FACE DROP AXLES (A60432)
(2) NOS-8 LUG-...
2019 Harley Davidson FLHTP Electra Glide Motorcycle (A56859)
2019 Harley...
2019 CATERPILLAR 326FL EXCAVATOR (A60429)
2019 CATERPILLAR...
