Tractor heater?
/ Tractor heater? #21
.............I currently run the new style with configurable vents (24V / 45 Amp) and it seems comparable to a 1500W space heater.............
With 24 volts and 45 amps it calculates to 1,080 watts. I can see that feeling comparable to a 1,500 watt space heater in the cab. the other calcs don't make sense. I went to their website and it looks to me like they have some bafflegab going on.
/ Tractor heater? #24
"bafflegab" ...thats sounds scary....lol
locknut, did I read that correctly, you are running a 24 volt system on your tractor.
/ Tractor heater? #25
Yes. 70A Delco 1-wire alt driven at mid pto.Two L&G batteries mounted underneath for the voltage storage. I use it for the heater and two 24V actuators for the v-plow up front.
/ Tractor heater? #26
Very nice set-up.:thumbsup:
/ Tractor heater? #28
Locknut,
Where did you get the nice digital gauges?
Steve
Coleman-Aire thru ebay.Wouldn't recommend one though.DOA when I got it.Sent it back.Worked ok for a couple years,then last year it quit.Supposidly made for aircraft.Maybe tractor use is too much vibration.Been thinking about removing it from the blockoff screen and install a volt gauge.
/ Tractor heater? #29
What is this "snow" stuff you refer too?
Will it effect how I mow my lawn right before Christmas? :)
I've spoken to the reindeer, they have agreed to leave a little something extra at your place this year.... Let's call it fertilizer ;)
[be careful hosing off the roof.... don't stand directly under where you are spraying]
/ Tractor heater?
Snow is our reality check from God to quit having so much fun, kinda like the summer heat for you guys..:)
/ Tractor heater?
Very neat!
/ Tractor heater? #32
I have 2 heaters fed off a circulating pump from a Dodge Durango. I also put shut off valves in series so i don't need to drain the cab in the summer. when the wind was blowing in sub zero temps the windows would ice up before I added the second heater and pump.
IMG_20141207_213252_193.jpgIMG_20141207_213236_765.jpgIMG_20141207_213220_071.jpgIMG_20141207_213158_958.jpg
/ Tractor heater? #34
I have the heater from Curtis that is mounted above my left knee then i added one above my head on the right side. I have them plumbed in series and use the circ pump to feed them. Even with the engine coolant temp that normally runs below 140 I usually end up shutting one heater off because it gets too hot in the cab. They have the pump on ebay for around$37.00
/ Tractor heater? #35
Nice, so which parts are borrowed from the Durango?
/ Tractor heater? #36
1999 dodge Durango air coil from the ceiling. put one in my jd x585 . 3speed fan. gets hot as ****. hook to the bypass hose
2019 Ram 5500 Chassis Dump Truck (A64556)
2019 Ram 5500...
2019 INTERNATIONAL PROSTAR 6X4 T/A SLEEPER TRUCK TRACTOR (A67148)
2019 INTERNATIONAL...
2023 JCB 270T SKID STEER (A65053)
2023 JCB 270T SKID...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
UNUSED PARBREAK SP173 SNOW PUSHER (A65055)
UNUSED PARBREAK...
2021 Mercedes-Benz Sprinter 4500 Modified Food Catering Van (A64194)
2021 Mercedes-Benz...
