Tractor heater?
/ Tractor heater? #21
.............I currently run the new style with configurable vents (24V / 45 Amp) and it seems comparable to a 1500W space heater.............
With 24 volts and 45 amps it calculates to 1,080 watts. I can see that feeling comparable to a 1,500 watt space heater in the cab. the other calcs don't make sense. I went to their website and it looks to me like they have some bafflegab going on.
/ Tractor heater? #24
"bafflegab" ...thats sounds scary....lol
locknut, did I read that correctly, you are running a 24 volt system on your tractor.
/ Tractor heater? #25
Yes. 70A Delco 1-wire alt driven at mid pto.Two L&G batteries mounted underneath for the voltage storage. I use it for the heater and two 24V actuators for the v-plow up front.
/ Tractor heater? #26
Very nice set-up.:thumbsup:
/ Tractor heater? #28
Locknut,
Where did you get the nice digital gauges?
Steve
Coleman-Aire thru ebay.Wouldn't recommend one though.DOA when I got it.Sent it back.Worked ok for a couple years,then last year it quit.Supposidly made for aircraft.Maybe tractor use is too much vibration.Been thinking about removing it from the blockoff screen and install a volt gauge.
/ Tractor heater? #29
What is this "snow" stuff you refer too?
Will it effect how I mow my lawn right before Christmas? :)
I've spoken to the reindeer, they have agreed to leave a little something extra at your place this year.... Let's call it fertilizer ;)
[be careful hosing off the roof.... don't stand directly under where you are spraying]
/ Tractor heater?
Snow is our reality check from God to quit having so much fun, kinda like the summer heat for you guys..:)
/ Tractor heater?
Very neat!
/ Tractor heater? #32
I have 2 heaters fed off a circulating pump from a Dodge Durango. I also put shut off valves in series so i don't need to drain the cab in the summer. when the wind was blowing in sub zero temps the windows would ice up before I added the second heater and pump.
IMG_20141207_213252_193.jpgIMG_20141207_213236_765.jpgIMG_20141207_213220_071.jpgIMG_20141207_213158_958.jpg
/ Tractor heater? #34
I have the heater from Curtis that is mounted above my left knee then i added one above my head on the right side. I have them plumbed in series and use the circ pump to feed them. Even with the engine coolant temp that normally runs below 140 I usually end up shutting one heater off because it gets too hot in the cab. They have the pump on ebay for around$37.00
/ Tractor heater? #35
Nice, so which parts are borrowed from the Durango?
/ Tractor heater? #36
1999 dodge Durango air coil from the ceiling. put one in my jd x585 . 3speed fan. gets hot as ****. hook to the bypass hose
2022 EZ-GO ELITE...
2008 Ford F-250 4x4 Crew Cab Pickup Truck (A64556)
2008 Ford F-250...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A64556)
2022 Peterbilt 567...
2012 CASE CX350C EXCAVATOR (A65053)
2012 CASE CX350C...
2019 International DuraStar 4300 26ft. Reefer Box Truck (A64556)
2019 International...
JOHN DEERE 7810 TRACTOR (A64278)
JOHN DEERE 7810...
